Old 05-09-2005, 10:08 AM   #1
tonkatoyx2
I ordered 20 blue leds with resistors.
Not even knowing how to hook them up
and not even know what the resistors do.
i saw that alot of people rave about this stuff so i went ahead and got them and
i just figured i could figure it out with the help of you guys
so can you guys tell me how to hook up these leds any where and what do the resistors do?
Thanks
Old 05-09-2005, 11:18 AM   #2
TwistedDreams
VIP
TwistedDreams's Avatar
TwistedDreams is an unknown quantity at this point
Send a message via AIM to TwistedDreams
20 leds kind of excessive huh?lol
resisters I believe resist to much juice from your battery I could be wrong so if I am then someone currect me on that.
Gunnery Sergeant Hartman: "I'm going to rip your balls off, so you cannot contaminate the rest of the world."
TwistedDreams is offline   Reply With Quote
Old 05-09-2005, 11:25 AM   #3
Cyber Knight
Swank
Cyber Knight's Avatar
20 LEDs aren't many if you use a few in each spot. Resistors prevent too much current from going thru your circuit so you don't cook the components (assuming you use the right resistor(s)). One of these links should get you started.
LED/resistor calculator and links to more info.
LED/resistor calculator with diagrams.
Old 05-13-2005, 06:36 PM   #4
gxryan
Okay here are some basics for led's
ur car probly runs at like 14V's and each led that u put in series is a 0.7V drop
but each led has a maximum current limit. if u exceed that u will blow up the LED's
so for example
if u have 2 led's in series thats a 1.4V drop and a resistor in series.
there is about 12V's accross that resistor.
so take 12V divide by the maximum current that the LED's can handle thats the size resistor u want.....
and work out accordingly to how many led's in series u want.....
Old 05-13-2005, 06:53 PM   #5
^ if you could follow that, its pretty accurate. basically, connect the resistor to either side of the leads on the led. (keep the LED + and - separate) connect power to the longer lead, and ground to the shorter one.
and your done. led lighting... woo hoo!
Old 05-13-2005, 08:35 PM   #6
bigd6983
what voltage are the LED's recommended at......if you hook them up right you could do without the resistors.........tell us where you want the led's, how many you want in each spot, and the specs on the LED's.........
Old 05-14-2005, 04:28 PM   #7
eag182
so for example
You may want to try and replace your interior lights with them. Mine (dome, mirror lights) are 12V, not 14V. There are a vast number of types of LEDs, a .7v drop is just one of many. Please tell us the specs of the LEDS and resistors and we will be better able to help you. The LEDs I ordered were rated at 3.5V. I will post a pic later.
