Old 07-23-2005, 07:43 PM   #1
switch
Hey , I installed my Pioneer deh-7700 in my car a few months ago and at night the thing is just way too bright.
I've turned the "Dimmer" feature ON in the Headunit, which dims the headunit lights whenever I turn the car lights on, but it really isnt much help.
Is there a way I can adjust the brightness of the lights with my Interior Light control?
On the wire harness (GM Data Bus) there is two wires. (Orange, and Orange/White) One of them says Dimmer, and the Other says illumination. I connected the Orange/White to the matching HU Orange/White wire. However, when I adjust my intereior dash lights, the HU stays the same brightness.
Anyone have any idea?
Thanks
Old 07-23-2005, 08:31 PM   #2
bigd6983
ok with the headunit off.............hold the function button i think it is, scroll through the settings and there should be a brightness level.........
Old 07-23-2005, 09:24 PM   #3
^ i second that one. function w/ unit off. also used to set the clock. (just found that out MONTHS after getting it installed.)
RTFM... READ THE F*ING MANUEL! i don't listen to that often.
(not to switch. that was for me)
Old 07-24-2005, 04:09 AM   #4
bigd6983
lol seriously.......pioneers are pretty easy, the manual is nice on pioneer for some eq settings, now on a pioneer or a kenwood id definately need the freakin manual........
Old 07-24-2005, 12:24 PM   #5
switch
Yeah I've done that (Turned it off, adjusted the brightness)
But im trying to get it so the HU brightness will adjust with the brightness of the interior lights.
Is it possible?
Old 07-24-2005, 01:27 PM   #6
oh... um... not that i know of. bigd might know.. he's pretty knowledgeable w/ such things...
Old 07-24-2005, 01:57 PM   #7
bigd6983
you would probably have to tap into the output on the dimmer switch but even then im not sure......im not sure what the dimmer range is on the stock switch compared to what the head unit needs........
and you said you try'd the orange/white wire, why not try the orange wire now seeing as how the other one didnt work, try the orange off your deck onto your orange/white on your cars harness(as long as thats the dimmer....)
ive never really looked into this cause I never cared, i like a bright HU, and the brightness level on the settings has always worked for me whenever i wanted to tone it down........
Old 07-24-2005, 10:47 PM   #8
mikegett
mikegett's Avatar
Some of the newer HU's can't operate with a external dimmer. It all depends on the type of display used. Older lcd technology dims with voltage while newer displays are dimmed by varying resistance inside the HU.
Old 07-24-2005, 11:53 PM   #9
jamcllw
the orange/white wire use the orange/white wire
