07-26-2005, 01:27 PM
I am am thinking about picking up a new deck which is the kenwood ddx 7015
Its double din and I think it will fit in the stock area with a little mod but not sure any one have a double din installed?
if so was it hard to fit in the existing stero slot
heres a pic of the deck
[font=Arial]<span style=\'font-size:8pt;line-height:100%\'><span style=\'color:red\'><span style=\'font-size:12pt;line-height:100%\'>
2001 alero cleared corners ,custom dual exhaust ,red neon under glow kit
Peace to all my brothers from a diffrent mothers and all you ladies keep lookin beautiful
ALLHEAT</span></span>[/font</span>]
07-26-2005, 02:42 PM
Only thing I'd be worried about is how much room you are going to have for the screen to swing out...it's a great deck though I seriously thought about doing that with my car, but I ended up just getting an Alpine HU instead...I'm sure someone with a double din will answer your question...I think it WILL fit in there...again I'm just not sure if you'll have the room for the screen to swing out.
You ever take it off of any sweet jumps?
07-26-2005, 02:45 PM
won't fit Alero's are 1.5 DIN. The later years may have 2 DIN like the Grand Ams.
07-26-2005, 03:51 PM
later years like what i have 2001 is that late enough one of the decks with tape and cd plus when you open it up theres some space below and above
07-26-2005, 03:54 PM
i think it's 03-04 Grand Ams that have the double dins not sure about Aleros
07-27-2005, 09:02 AM
Yeah you're right...I just realized that now, because of the mounting kit that is needed for it. I have an '02 and Jamcllw is right. Because if you put a regular deck in the mounting kit you use usually has a small little pocket underneath to help fill in the space...so it is a 1.5 Din.
07-27-2005, 03:43 PM
what if you do it with out the mounting kit and just make custom brackets think it will fit then
07-27-2005, 03:47 PM
no your going to have to cut into your trim panel and odds are it's going to look like crap
07-27-2005, 09:13 PM
Since when is the Alero a 1.5 Din? I have a stock deck from an 03 Alero and I also have a 1.5 Din Pioneer - I compaired the 2 and the Alero is atleast an inch taller then the 1.5 din.
-Aaron
'04 Alero GL1 - 2.2 DOHC A4
'00 Intrigue GLS - 3.5 DOHC A4
07-27-2005, 09:24 PM
Please see my first comment. You have a later year car.
07-27-2005, 09:26 PM
The Alero Stereo on that picture is from an 01 GLS
I still have the factory in my car - but it's the same.
-Aaron
07-27-2005, 09:41 PM
^^ What are you talking about? The only picture in this thread is of an aftermaret Kenwood deck that's double din. I know for a fact that it won't fit into a 2000 without modification. And I'm pretty sure that it won't fit into a 2001 either.
07-27-2005, 09:46 PM
I'm a crackhead - I forgot to attach my picture
The 99-00 are Din 1.5 - 01+ are 2x, so his WOULD be a 2x and he could use that Kenwood.
-Aaron
07-27-2005, 10:46 PM
actually...all alero stock headunits are double din. i have 2 '99 alero decks(actually one is out of an eighty-eight) and one stock gmc 1.5din. you can easily tell the difference between the two. HOWEVER, the way GM made the double din unit and the bezel is having it fit BEHIND the bezel flush to it. there is absolutely NO WAY you will get an aftermarket double din to fit, cause they just arent flat on the front like the stock is. a 1.5 din should fit pretty good though.
07-28-2005, 02:31 AM
Thank you soundxtreme for the correction. This is a question asked alot on here and I am getting tired of being the only one to correct it. The industry standard does not apply to the shape of a bevel. It goes by the size of the radio. Ford uses a round bezel mounted to the front of the climate control and HU. However, the radio is still a single din. All aleros have a double din opening but are restricted by the outer bezel. If you were willing to dremel the corners out, the double din will fit. I realy don't think it will look bad. My eclipse single din has a larger trim plate that won't fit between the bezel. I dremeled out where the trim plate sits and recessed it in. I then took black foam ( bought at wal-mart in craft area) and glued it to the back of the bezel. A quick cut with the utility nife and no gaps.
08-14-2005, 04:08 AM
Hey mike thanks for the idea i am going to try that i love the deck and have to have it plus it would look bad ass in the stock stereo area
