04-21-2008, 03:48 AM
#61
New and Improved
my mouth is watering over what you could accomplish with a chevelle....
04-21-2008, 04:51 AM
#62
hey mike ... ill swap you cars and a bit a cash for yours ... then you still have a daily driver and "mine" would then finally have the turbo :P
04-21-2008, 07:57 AM
#63
Originally Posted by kwhauck
damn, that sucks, kinda funny thought cuz that is exactly what happened when my motor blew 2 years ago, except also the #6 piston turned into about 5 pieces. I was trying to thread the spark plug back in with my wife pouring ice onto my hand just so I could get the car to limp home.......and with the project car, do whatever you want, that's all i am doing with the alero, my dreamcar.........
yeah, shit like that happens when the #6 cylinder is last in the coolant flow path and last on the fuel rail.
04-21-2008, 08:20 AM
#64
too bad you can't redesign to have fluid/coolant come in from each side, and drain out the center front/back...
04-21-2008, 05:07 PM
#65
Boost Guru
Originally Posted by BlackJack
Yeah, the only reason I'd de-mod it is because I want to keep the car for a daily driver. I still love the car, but when I think about how much more I planned to pour into it over the next couple of years, it makes me realize how I could afford my Chevelle for about the same money.
Just keep the Alero and get the Chevelle. That's what I'm doing in probably less than a month, but it's not a Chevelle I'm getting...
04-21-2008, 05:14 PM
#66
yeah, then it would be cylinder 2 and 5 that were overheating. You wouldn't get away from it either way, but good idea in concept
problem is ONE of them is going to be in the 10's....and there's only money for either or, but not both
Just testing the waters, but what do you guys think the Alero would go for the way I built it (54k miles) and everything in proper order?
04-21-2008, 05:16 PM
#67
$5, i'll buy it
04-21-2008, 05:29 PM
#68
Originally Posted by [ion] C2
$5, i'll buy it
somehow I knew your integrity wasn't going to factor into this equation...hahahahaha.
Just remember the old addage....."Speed cost money" If you want $5 worth of fast, I can send you a bolt off of this wastegate or blow-off valve.
04-21-2008, 06:22 PM
#69
hahaha.....I didn't see any of the posts after my last because my email notifier apparently wasn't working.
sell me your turbo set up....and thats a good start on the chevelle
04-21-2008, 06:49 PM
#70
Entice me with a reasonable offer, and what components you'd be considering inclusive(UIM/LIM, etc.)
04-21-2008, 07:03 PM
#71
you could always modify the fuel lines and the rail to accept constant equal flow... That's what I'll be doing on my new car an 02 wrx once I get my new compressor wheel and housing on my turbo, mod the injectors for 800cc and switch to e85
Seriously though... I would do that just in case you are running a bit lean on that cylinder, also have you checked what the cars fuel rails are flow rated at?
Live for something or Die for nothing
#72
pm sent.
04-22-2008, 01:03 AM
#73
If I continue, the fuel rails will both get feed at once, and I already have a dual inlet/single outlet FPR.
pm sent.
PM received, and replied.
04-23-2008, 04:33 PM
#74
atleast run it at the track on all 6 before you demod it, if thats what you deside to do.
HAS
-'01 alero "442" 3.4 v6, 8.2 taylor wires, 2 10's , WAI, 2.5" custom cat-back exhaust w/ dual super 40 mufflers and, KYB-GR2 struts. 15.701@87.69mph.
-'97 s10 4.3 v6, alpine head unit, camaro rims, 2.5" cat-back w/Edelbrock SDT, Edelbrock TES headers, HPPIII, and 8mm taylor wires. 15.505@87.42mph
http://www.cardomain.com/id/s104-banger
videos-
http://youtube.com/watch?v=YvkbtiBirVo
http://youtube.com/watch?v=WnmqBZkdmAM
04-23-2008, 05:00 PM
#75
I'm still up in the air about it. But I still haven't had any (serious) replies on what people think it's worth.
04-23-2008, 06:08 PM
#76
1 million, billion, bajillion, kajillion, billion... dollars....
04-23-2008, 06:50 PM
#77
mine was more than serious, i dont know the cost of a kit like this, so i told you to give me a number that suites you.....that way I dont low ball you and look like a rooster.
04-23-2008, 08:31 PM
#78
if you think about it its not a bad idea to run it one last time. that money from the first n-body in the 12's would only help you get your chevelle going. i know its not a lot, but its somthing. after all that hard work you put into it, you only get to see it run a broken down 14.5 sec quarter when you know it will run tons faster. plus all us alero guys can brag about and alero being the first n-body in the 12's.
HAS
videos-
04-23-2008, 09:43 PM
#79
That would be the first v6 n-body -Spy already ran that in his 4 cyl n-body
04-23-2008, 09:50 PM
#80
Not bad ion what have you done to the car?
