08-03-2012, 05:17 PM
lowering
I need to replace my suspension anyways so I figured might as well do it right and lower her I only want to drop her about a inch does any one know where I could get a kit for this I do not want to cut the springs no air ride any do's or dont's I should be aware of ive never lowered a car but ive lifted a bunch of trucks and jeeps.
"Horsepower sells cars,Torque wins races." ~Carroll Shelby.
2004 oldsmobile alero gl1 sedan, cold air intake from chrome intakes, catback exhaust, ceramic brakes and cross drilled rotors.
Future mods are going turbo charged, paint, new exhaust system, converting rear brakes to discs, and hopefully a 6-speed tranny swap. Not exactly in that order.
08-03-2012, 05:32 PM
Wide Open Throttle
We have a setup that will lower it about an inch at most. The beta tester loves his setup, and is ready to experiment with other springs. I need to find out what the price is to make a set if this is something you are interested in.
08-03-2012, 05:36 PM
It is something i am truely interested in if you could get me a price that would be great im starting to get memory steer but im still on the stock suspension bought with the car
08-03-2012, 09:48 PM
The wot tech ones are supposedly nice. I would go with them. If you guys dont work out a deal though eibachs are like 1-1.5in drop.
08-04-2012, 04:17 PM
Wide Open Throttle
They are $800 shipped for 4 KYB GR2s setup with coil overs and new strut mounts all around as well. You can then experiment with other springs if you want it lower or stiffer/not as stiff.
08-04-2012, 04:56 PM
I want pics ben. Hook me up.
08-04-2012, 05:28 PM
do they come already put together?
08-04-2012, 05:56 PM
Wide Open Throttle
Yes, they are a bolt on setup.
08-04-2012, 06:17 PM
Thats good umm ill have to see if I can get the funds together. I would like a pic
08-04-2012, 08:52 PM
Wide Open Throttle
2 pics attached.
08-04-2012, 09:42 PM
mmmmm sexy, you should make a set with AGXs..
08-04-2012, 11:14 PM
Agx's are on backorder till race season is over
08-05-2012, 01:34 AM
WOT-tech, those are beautiful.
08-05-2012, 01:49 AM
Are those collars welded on ben or are they just chillin
08-05-2012, 12:56 PM
Wide Open Throttle
They aren't welded. No one here wants to weld to a tube with compressed gas in it:P
08-05-2012, 06:36 PM
Pssh 1 tack weld and done dont burn through the strut
08-05-2012, 07:26 PM
Id like them in a blue haha
08-05-2012, 07:31 PM
just an idea... if you wanna go lower completely cut the welds and drop the threads all the way to the bottom like the one I have.... I know it would be time consuming but grinding with a controlled amount of water drippping on the grinder blade will prevent the overheat...
08-05-2012, 07:37 PM
I dont want to cut nothing I have to replace my suspension as it is and I wouldnt want to cut anything
08-05-2012, 07:40 PM
... where do you thing is the original lower spring perch on these one ???
