10-24-2013, 11:45 AM
led fast flashing!
I would like to change my turn signals to leds but so far every single type iv tried just hyper flashes really fast not like normally what do I gotta to do?
2003 alero 2.2 ecotec tinted windows, cold air intake, strut bar, full pacesetter exhaust, HID lights, grill mesh, brembro brakes, kicker l7, chipped and more but looking for more mods i would like to keep my car luxury, clean and a head turner.
i do auto detailing so my car is always spotless [SIGPIC]
10-24-2013, 12:06 PM
Get a load resistor and splice it in... problem solved!!
10-24-2013, 01:08 PM
Add to the load resistor comment - splice one in on the front each side FIRST, don't do the back until you find out that it didn't do the job.
And - you don't have to do the brake lights, unless you get a "Service Vehicle Soon" (not to be confused with the "Service Engine Soon") light. THAT light is for "Hey, Bubba, youse gotsa burnt out bulb. Replace it, dimwit!!" not "OMG emissions are compromised we're gonna blue screen the mutha!" To get back on track, unless THAT lights up, the brake lights are fine LED. The turn signals not so much since it's designed to hyperflash if a bulb burns out to let you know it's out. And since the current reduces with LEDs, which is what the flasher uses to determine a bulb is out ...
RwP
10-24-2013, 02:26 PM
epic...
2004 olds alero R.I.P 242,500
1995 f-150 5.0v8 5sp 143,xxx(redneck truck)
Now searching for a new Ho!
Originally Posted by Redog
He no crazy, he WIALERO!!
10-24-2013, 02:40 PM
Search man. Alot of this stuff you ask about has been covered.
Originally Posted by Oldsnut
Originally Posted by tipnitty
10-24-2013, 03:08 PM
I have heard a couple people had issues with the cruise not working from led's in the brakes without resistors are the load isn't th same and would trip thecruises to shut off.. i cannot confirm this though... mine work fine
10-24-2013, 06:41 PM
OMG!!!!! my cruise did stop working! im going to change the bulbs back tonight!
10-24-2013, 07:02 PM
so if I put the bulbs back in will my cruise work!!!! omg!
10-24-2013, 11:09 PM
It should. I use led bulbs everywhere but my fog lamps. Interior too. I have a resistor wired into all 4 corners with no issue. Alternately you can just cut the black wire on your fronts and that will fix the issue as well so long as you don't mind both bulbs up front blinking as one instead of in sequence. I prefer mine this way so I left it.
10-25-2013, 12:20 AM
Ok so I have installed the stock bulbs and my cruise works like the light comes on and when I hei set the cruise light comes on, on the dash but it doesn't catch the car just slows down? Do I have to rese it now or something?
10-26-2013, 01:03 AM
epic...
*snicker*
Blame three takings of Remedial English Writing in college for that.
That, and way, WAY too many "Expense Justifications". A man can only write so many of them before he gets bent somehow
RwP
