05-04-2012, 09:29 PM
Lx9 question
Is it possible to use the stock crank trigger in the stock location by swapping the timing chain cover from the 3400 to the 3500 engine? and using the stock 3400 crank pulls
05-04-2012, 11:00 PM
Crank trigger is a different set-up on the LX9, so using a stock 3400 external, I doubt will work.
Maybe Ben with chime in
05-05-2012, 03:27 AM
Why would you go the other way around?
Didn't you bought a complete working 3500 engine?
Would be a waste of time & money to use the 3400 parts on the 3500 engine
Either swap the entire engine (3500) in your car or keep the 3400 & swap all the top of the 3500 on it
Otherwise you wont get the performance you're looking for & it be more trouble then anything else... IMO
05-05-2012, 04:22 AM
Ok look it's my damm car and I'm doing the damm swap not you. So I'm doing it how I want to do it so it's easier on my wallet. It's getting the 3400 upper intake and that's that. If your so damm insistent on doing a full 3500 swap with the 3500 upper go do it your self And stop telling me that I need to do what you feel is neccacary for this swap !!!!.....mmk
05-05-2012, 04:24 AM
I did a bit of digging and found out that i can't do it that way. I thought it was the sensor behind the pully that was being moved. Lol I had a brain fart I guesse
05-05-2012, 04:45 PM
Chill man!
It was just some questions & suggestions i was trying to help you save money & not get in to all kind of problems for nothing
See what i mean you'll get a lots of that by going this way
Now i could understand if the 3500 engine was not working properly & wanted to replace defective parts with the 3400 engine but as far as we know you bought a good working 3500 engine so i fail to see your logic in the way you're going with this...? (no offense)
05-05-2012, 05:50 PM
I swear to effing god !!! It's my effing swap I'm putting the 3400 upper on the 3500 moter I dont give a damm what you think of it. Piss off dude like I effing said its my car and I will do what I want to it. How I want and when I want. Now if you wanna go ahead and stfu that would be just great. Mmmk..
(lets not edit some one elses post kwhauck)
05-05-2012, 07:13 PM
I swear to effing god !!! It's my effing swap I'm putting the 3400 upper on the 3500 moter I dont give a damm what you think of it. Piss off dude like I effing said its my car and I will do what I want to it. How I want and when I want. Now if you wanna go ahead and stfu that would be just great. Mmmkkk
lol hes just asking a question LOL
05-05-2012, 09:39 PM
and to think I didn't want to post in this thread cause I thought my skill level isn't at this point yet... well at least my sense of humor is... LOL... And jawa is right its his thread..
05-05-2012, 09:42 PM
YOU HAVE TO SWAP A BUNCH OF PARTS OVER TO THE 3500 for it to work properly. Obviously you haven't done much research.....
This should help you.....helped us A LOT.....
http://dl.dropbox.com/u/534555/3500%...dy%20Swap.docx
05-05-2012, 09:46 PM
Wide Open Throttle
I don't think he wants any help.
05-05-2012, 09:54 PM
He got all the help he needs in that guide anyways.....except for the cam sensor....doesn't have anything in there about that. Have to swap it over but like i said be careful cause the part where the bolt goes through WILL break easily since it's only plastic.
05-05-2012, 10:22 PM
You know, today I was looking at a cam sensor I pulled out of an '02 Alero and it actually has a metal collar inside the screw hole. JAWA does seem to have a chip on his shoulder, so best of luck to him on not screwing something up.
05-05-2012, 10:32 PM
Yea but that doesn't help with the breaking issue....if it's in the hole.....the problem is you gotta pry it out and the ONLY spot to pry on is the tab....cause you can't get any other tool in there (maybe a 30 degree pick or something) but we had problems getting to it. Then it came out.....but the tab broke Yes, jawa does have a chip on his shoulder....thinking this is gonna be done in a weekend....that's exactly what i thought He'll learn.....and hopefully he doesn't rush things cause there is a lot to do and if you miss something.....not good.
05-05-2012, 11:37 PM
I do appreciate the help n all but when some one won't shut up about why I'm putting the 3400 upper on the new moter it pisses me off, It will be done in a weekend working around the clock till its done . I also hate it when people tell me I can't do somthing
05-05-2012, 11:40 PM
You better be at ass with this thing!
05-05-2012, 11:50 PM
I'm gunna try my best to be there. Might be camping in the woods to save money. But I plan on being there
05-07-2012, 12:53 PM
Let play nice huh? (edited by kwhauck)
So much for freedom of speech and freedom of expression on this fourm
05-07-2012, 02:57 PM
Whoever said anything about freedom of speech and expression on this forum?
Just follow the rules.........Thanks!
Originally Posted by Oldsman
* Bashing-
Please keep in mind that this is a public forum. If you ask for opinions about something you have done, you can receive critical comments as well as positive ones. Do not take this personally, as everyone is entitled to their own opinions. If someone doesn’t like what you have done, then ignore them and move on. Excessive abusive comments towards another member. For example, if someone posts a picture of a car that you think is horrible, it is ok to post your opinion that is horrible in your opinion. However, it is NOT ok to say something like "your car is a piece of crap, you should just drive it off a cliff to make it look better." Additionally, keep in mind that if it is you that started a thread, and someone has some negative comments, you should NOT get angry at someone just because they don't like what you've done. Everyone IS entitled to their own opinions. Replying angrily only leads to more bashing. Bashing other members and getting into fights is not allowed, if you have a personal problem with a member, take it up with them on pm. We don't care about your dirty laundry.
05-07-2012, 03:19 PM
Bah what ever I'm over it
