03-28-2005, 11:09 PM
if any of you have been reading some of my posts.....you guys probably know that i have 2 12"s in the trunk. although it sounds f***in' awesome they slide around when ever i turn or accelerate too fast. so for now i have my sub boxes in there holding them in place.
is there a good way to secure the box down and make it look good at the same time? i don't want to go get "L" brackets....i want it too damn good?
does anybody have good suggestions or pics? i'm up for any ideas....
03-28-2005, 11:13 PM
ya, quite driving like a maniac! could make a bracket and screw it to the floor just dont put a hole in your gas tank.
03-28-2005, 11:16 PM
well that's the thing.....i don't drive like a maniac unless i'm challenged. i'll accelerate from a light and hear a big thump from the subs hitting the back wall of my trunk.
i'm just wondering if anybody had anything that really worked for them
03-28-2005, 11:29 PM
My sub carpet must give more friction because I don't have this problem. However, there are metal strips that you place on the bottom of things to keep them from moving. The metal strip has two bent prongs that scoop into the carpet to hold it in place.
03-28-2005, 11:40 PM
that seems like it would be good....easy enough too! but i'm a guy that likes fancy stuff....i'll do that for now.....but i'm going to see if i can use some of my inginuety (sp?) to come up with something pimp
03-28-2005, 11:41 PM
^where can you get those medal pieces?
03-28-2005, 11:42 PM
the only thing that was holding mine was the carpet from the box and trunk, now i have an amp rack between the trunk wall and subs so it forsure won't but i never had that problem before
03-29-2005, 12:12 AM
the box i have has plastic corners on it....so i might put something on the 4 corners at first to see if that does anything....it's a good looking box tho.....i'm going to buy a digital camara on pay day so i can post up some good photos!
03-29-2005, 12:18 AM
if there just little plastic corners you could maybe just take em off unless it makes the box look bad
03-29-2005, 12:20 AM
For mine I went to Home depot and bought a couple of metal straps that are used for strping joist together. They already have 2 big holes in them and a bunch of little holes. I used the bolt from the teather anchors to secure the straps to the car and bent them to the contors of the car unde rthe carpet than cut a small slit in the carpet for them to come threw and secured tham to the box. no more moving and also better gaurded against theft.
2002 GL2 4DR, MYMODS:In dash 7" VGA Widescreen monitor, XM Satalite Radio, Clarion Amp, 2 10" Audiobanhn DVC Subs Hidden HitchTrailer Hitch, Grill Mesh
03-29-2005, 12:27 AM
Get some MDF from Lowe's or Home Depot and cut it to the shape of your trunk then screw them bitches down. Put some carpet on the new floor and youre set. Its a little hard to get to the jack and spare tire though but it will help hold your stuff down.
03-29-2005, 12:32 AM
that sounds like a waste of time and money to me, and doesn't make sense
ive never had a problem, but i guess your box is riding on those plastic corners. i know i had a uncarpeted box for like 3 days while i waited for the carpet (no, i couldn't wait to hear the subs) and that thing always slid around no matter what, as soon as i carpeted it, it went away
2001 Alero GLS - Sold!
03-29-2005, 12:41 AM
Originally posted by mike2002+Mar 29 2005, 12:32 AM--><div class='quotetop'>QUOTE(mike2002 @ Mar 29 2005, 12:32 AM)</div><div class='quotemain'><!--QuoteBegin-FantomForceCustoms02@Mar 28 2005, 11:27 PM
Get some MDF from Lowe's or Home Depot and cut it to the shape of your trunk then screw them bitches down.Â;-) Put some carpet on the new floor and youre set.Â;-) Its a little hard to get to the jack and spare tire though but it will help hold your stuff down.
[/b][/quote]
It's not really a waste. It gives you something to screw into besides the trunk floor where you could hit the gas tank or anything else under there. I have my sub box, amp, and cap screwed into it too. A little nicer look too I think.
03-29-2005, 12:44 AM
yea ive got a false floor in my trunk but theres really not much else in there, not even carpet. hehe
03-29-2005, 01:10 AM
hmmm.....never thought about that.....i guess you just gotta make sure you don't get a flat!! lol!
but the box i got from Best Buy, it's carpeted and has protective corners on it like they expected it to move around!! it doesn't make sense....i tried to take one of them off but it looked like it was going to tear the carpet...and i didn't want to deal with it.
thanx for the imput guys!! i'm going to see if i can do the fake floor deal...i used to work construction, so i got some tools that i can use.
i'm thinkin'bout putting some neons in there to accent my subs......is it worth it?!? and where do i hook the power up to?
03-29-2005, 12:01 PM
There called L-brackets and you can get them for .10 cents at home depot and another .15 cents for the screws to hold them.
{} < = box
L= L braket so {}+L= {}L problem solved
03-29-2005, 01:01 PM
Originally posted by isellalerodrop@Mar 29 2005, 12:01 PM
There called L-brackets and you can get them for .10 cents at home depot and another .15 cents for the screws to hold them.Â;-)
{} < = box
L= L braketÂ;-) so {}+L=Â;-) {}L problem solved
If you had read his original post he doesnt want L brackets.
I used to use Strips of double sided velcro. They worked really well. And velcro is CHEAP.
Pheenz Motorsports Founder
03-29-2005, 05:58 PM
First off MORONS
EVERYONE ON HERE L BRACKETS ARE BETTER THEN NOT GETTING ANY MONEY WHEN IT GETS STOLEN.
If you dont want L brackets, take your subs out, and drill and bolt the box to the floor pan of your car. you cant see it, use 4 count em, FOUR bolts to secure the box MINIMUM.
I have heard of claims to insurance companys denyed because only 3 bolts were used...
With this method you will not see the bolts only your box, Then screw the subs back in, now your box is near IMPOSSIBLE to steal. and guess what... wont move.
03-29-2005, 11:24 PM
if it is screwed down just north of the spare tire is there any way of hitting the gass tank?
03-29-2005, 11:33 PM
yeah....i looked at it...and it doesn't give you much room to put some bolts down.
but thanx for all the imput guys....i have a couple different angles i can approach to this now.
