09-05-2007, 04:00 PM
4th CV axle w/ air ride! I love riding low but our CV sucks!
MMMMMMMM.. grease to clean ... NOT!
I'd just changed it out in april too! .. eff the 3rd one w/in a year. Oh well! easy swap. 30 mins or less.
09-05-2007, 04:13 PM
Did you reck the joint or did the boot just get a hole in it?
09-05-2007, 04:15 PM
Boot torn! I dunno why. its only that side (passenger) that all of them get a leak in the inner boot.
I've tried them all, Napa, autozone, oreilly's, pep boys. All them leak still.
09-05-2007, 04:24 PM
Huh, yeah I'm bagged and I've already done one but on the driver inner. I'm assuming you got the universal boot made of rubber not the oem plastic one's..
09-05-2007, 04:30 PM
It's just that these cars were not lowered intentionally so the components of suspension/transaxle will not match
09-05-2007, 04:32 PM
no i just change out the whole axle each time. I never do only a boot swap. Lifetime warranty .. just go back to autozone and swap out.
09-06-2007, 01:25 AM
Man, I hate cleaning up that mess that makes. You might see if you can slide the boot closer to the joint and that might make it hold up a little better.
09-06-2007, 04:50 AM
ya, both mine are blown. drivers is just a little cracked, pass side is effed. completely exposed. im neglecting changing them, mainly cause theyll jus blow again
09-06-2007, 10:21 AM
I Have ONE NUT
Never had any problems. Mabey mines coming!?
09-06-2007, 12:56 PM
is urs daily driven? 20-30k miles a yr? hahahaha
09-06-2007, 01:01 PM
I Have ONE NUT
Very very true. When I get back on the road next year I might just have to do a little dance.
09-06-2007, 04:47 PM
I had the same thing happen on my airbagged Ciera..and yes that mess it horrible to clean. I belive the combo of riding low and 13x7's was also responsible for blowing its tranny....getting a new one and blowing some gear in it. At least they covered the Gear replacement.
09-06-2007, 11:00 PM
alright, I'm not the smartest guy when it comes to lowered suspensions....but I can tell you I had a Baja Beetle that had extreme range of motion on the axles/CV's, under seriously abusive conditions. I'd try an off-road shop for some hardcore "split" CV boots. Not to mention you dont have to remove the axles if you had to change them.
09-30-2007, 11:22 PM
I Have ONE NUT
