Old 01-05-2009, 10:46 PM   #1
NickAlero2000
NickAlero2000 is on a distinguished road
Wheel Bearing suspicion....
Steady grinding near the front left side of the car...
can be described as follows:
my speed increases, the rapidness of the grinding increases. if i go slow the opposite happens...
anyone concur? I would wait for the tell-all lights to come on, but this sounds REALLY bad...
NickAlero2000 is offline   Reply With Quote
Old 01-05-2009, 11:08 PM   #2
change, might also be a sticking caliper....
Old 01-06-2009, 12:36 AM   #3
NickAlero2000
i thought that too, but my entire brake setup is less than 10 months old....
R1 Concepts, calipers brand new OEM and ceramic pads all around....
Old 01-06-2009, 10:41 PM   #4
NickAlero2000
bump....anyone else???
Old 01-06-2009, 11:19 PM   #5
comanche
comanche is an unknown quantity at this point
I have had identical symptoms with bad wheel bearings on more than one car.
comanche is offline   Reply With Quote
Old 01-06-2009, 11:51 PM   #6
sounds like it could be the axle or cv joint aswell, but i can tell you its either the wheel hub or axle, how many miles on the car?
Old 01-07-2009, 09:58 AM   #7
here's what you do, jack the car up next to the suspected wheel, if it off the ground and you can shake it back and forth, you need a new wheel bearing....Thanks, Kyle
Old 01-07-2009, 06:23 PM   #8
NickAlero2000
90,000 miles.
and kyle.....
it failed your test. it shook back and fourth with very little effort....
