1. "cat-back" is just a description of the kit. it's everything from the cat to the back.
2. If you have OBD-II inspections in FL, don't cut the cat. it's only impeding your performance because it's gone bad. if you don't have OBD-II inspections, then it's your call.
3. if you have any engine work at all, a performance muffler can only help if you have the proper exhaust work done. ie: 4" exhaust on any N/A Alero (with factory equipped engine) is retarded. 4" exhaust would be better suited for a heavily boosted applications.
Originally Posted by black
