Old 11-21-2011, 11:49 AM   #21
ok guys i did not use the light power to power this mod, i taped into the fuse box to a SWITCHED power source ( i chose the wiper fuse), and ran that wire to the ORANGE wire at the plug of the guage cluster, if you use the light (grey) wire the guages will only work when you have the lights on, also the reason my dash lights come on with the key is because i wired it to do that, they DONOT come on with the lights, every time the key is on the dash lights are on
Old 11-21-2011, 11:57 AM   #22
OFFICIAL WRITE UP
no pix yet
this explains how to make the gauges sweep on start up,
first take the gauge bezel out, then remove the gauge cluster,
unplug the connector at the back of the gauge cluster,
find the orange wire and cut it, leave plenty of wire at the connector so you have room to work with it,
next run a wire from the fuse box that is switched with the key ( i used the wiper fuse), you can tap into the power wire for the radio if you have a aftermarket radio
nxt you connect the wire you ran from the fuse box to the ORANGE wire going into the cluster connector,
then connect the cluster and re install it to the dash and reinstall the bezel,
turn the key on and enjoy full sweep on startup,
Old 11-21-2011, 12:00 PM   #23
Originally Posted by mmorello82 View Post
I'm with Luckilero7. How bout a how to. I have so many questions! How did you get the red dash lights? Did you get your A/C controls the same color. I wanna do this!
the ac controls are the same color as the dash
the bulbs are stock.....
but i took the cluster apart and applied a light filter film to the back of the gauge face, its actually called light filter gels and are available at most photography shops
Old 11-21-2011, 05:42 PM   #24
luckilero7
luckilero7's Avatar
luckilero7 is an unknown quantity at this point
Thank you, may attempt.
luckilero7 is offline   Reply With Quote
Old 11-21-2011, 06:07 PM   #25
Ya, I found out the intiror light was a bad idea. The sunroof fuse is a good one to tap into though.
Old 11-21-2011, 07:46 PM   #26
jhubbz
⌘ Irish Pride
jhubbz's Avatar
lol told ya so.
I figured a better and easier way to do this altogether. If you look at the pinout of the cluster, the orange wire is in A12. There are two purple wires, but the one you want to use is in A2. This wire is hot in accessory/run or start. Splice the orange wire into that purple wire and you are good to go.
Hooray!!!! btw triple beep is my radar.
Done lost my mind
Old 11-21-2011, 09:40 PM   #27
I figured one of those wires up there would do it... And I spent an extra 5 minuets running over to the passenger fuse pannel for the sunroof. Gash dang it.
Old 11-22-2011, 01:06 AM   #28
Glad to inspire
Old 11-22-2011, 08:45 AM   #29
Originally Posted by jawa View Post
Glad to inspire
It's a very nice mod.
Old 11-22-2011, 11:59 AM   #30
jhubbz
⌘ Irish Pride
jhubbz's Avatar
Glad to inspire
THANKS JAWA!!!! Big ups to you
I've always wondered why it would sweep only when you plug in the cluster, but not any other time.
Done lost my mind
Old 11-22-2011, 03:40 PM   #31
rocketfast321
rocketfast321's Avatar
rocketfast321 is on a distinguished road
Originally Posted by jhubbz View Post
lol told ya so.
I miss my gage sweep
rocketfast321 is offline   Reply With Quote
Old 11-25-2011, 11:33 PM   #32
Mike The Canadian
Mike The Canadian is on a distinguished road
lol told ya so.
hmm.. I wonder if this will work in the Malibu?
So in summary, cut orange wire, splice connector end into purple wire..
Right?
Mike The Canadian is offline   Reply With Quote
Old 11-25-2011, 11:54 PM   #33
correct, to be certain use a volt meter and test the wires, but the orange wire on the alero is the power wire for the cluster
Old 11-26-2011, 01:32 AM   #34
Just used jhubbz method worked great. but this way will reset your trip when you shut the car off
Old 11-26-2011, 02:34 AM   #35
Mike The Canadian
Hmm...damn that I don't want...
Old 11-26-2011, 04:22 AM   #36
Bah I never use the damm trip thing
Old 11-26-2011, 10:45 AM   #37
me either, just figured I would mention it because I know some people that use it religiously..
Old 11-27-2011, 03:03 PM   #38
rocketfast321
Hmmm ok i understand now. You need to use a switch source that goes dead when the car is starting.
2001 Alero vs 2001 Grand Am
Old 11-27-2011, 03:25 PM   #39
jhubbz
⌘ Irish Pride
jhubbz's Avatar
Dang, I didn't even notice that!! Oh well, I don't care anyway. That's what my ultragauge is for.
Idk about dead, but you want to use wire that only has power in ACC or ON. I used the one I did bc it was right next to it, and only had power in ACC or ON. Idk how you would keep the trip meter going.
Done lost my mind
Old 11-27-2011, 04:09 PM   #40
rocketfast321
I just did the mod, i'm gonna see how long the trip keeps the memory. If it's 5 seconds or so, it will be easy to put in a relay with a normal set of close contacts. And they will open when the car is starting, and close back.
