04-10-2009, 10:47 PM
Ringing Noise
So unless the A/C arctic looking button is on there is a rattling or mildly high pitched ringing noise. Any ideas as to what it could be? Not a big deal I just wanna try and fix it.
04-10-2009, 11:14 PM
ac compressor is grinding..... need it replaced...
04-10-2009, 11:39 PM
Couldn't it just be the clutch? Cause when you turn on the A/C, the clutch engages, and that is when he says he has no noise.
04-10-2009, 11:58 PM
Its Beer Thirty
He is saying unless his A/C is on it makes the noise. That the way I read it anyway.
Originally Posted by Daytona
04-10-2009, 11:59 PM
maybe clutch gone then? i have never heard of an A/C "clutch" going
04-11-2009, 12:02 AM
Its Beer Thirty
The clutch ingages on the compresser when you turn the A/C on. They go out quite often.
it could still maybe be the a\c compressor clutch not disingaging, if thats even a possible problem.
04-11-2009, 12:03 AM
Its Beer Thirty
I'm not sure on that. I'm sure it is possible though.
04-11-2009, 12:06 AM
never head it happen......
04-11-2009, 12:13 AM
from what you guys are saying it sounds like maybe the clutch is not completely disengaging from the compressor equaling a weak connection between the two and the ringing???
04-11-2009, 12:17 AM
is it a light metallic ringing? if so that is probably the problem. i have never heard of it happening, but if it did thats what it would sound like.
04-11-2009, 12:33 AM
Its Beer Thirty
Does it do it at idle? If so just pop the hood and go take a look at the compresser. The clutch will stop and start when the A/C is on. It shouldn't spin at all if the A/C is off. So if its spinning when the A/C is off thats your problem.
04-11-2009, 05:07 AM
Mine does the same thing, but not all the time. When A/C is on, clutch is engaged, so theres no noise, its when A/C is off that the noise can be heard. Because the compressor is free spinning and the clutch are worn out and make some metal on metal sound.
04-11-2009, 09:27 AM
Thats gotta be it Vinalero. I'm gonna have my local mechanic take a gander to see if anythin can be done, if not for a reasonable price ill just leave it.
04-11-2009, 12:53 PM
I've been told you can have the compressor rebuilded, but it has a price. Else I would look for one in a junk yard or over here.
