Old 10-27-2009, 06:52 PM   #1
WhiteV6
Wide Open Throttle
Cylinder head flow comparisons
http://wot-tech.com/flow.html
3 of mine, 1 of theirs. More info will be posted later.
Ben
WOT-Tech.com
60DegreeV6.com
Old 10-27-2009, 07:07 PM   #2
Bad99Olds
New and Improved
Bad99Olds's Avatar
Bad99Olds is on a distinguished road
Send a message via AIM to Bad99Olds
Impressive numbers Ben
Bad99Olds is offline   Reply With Quote
Old 10-27-2009, 07:19 PM   #3
bkathsalero
bkathsalero's Avatar
Good numbers for sure. Question though, why do the wot-tech manifolds stay lower at the begging of the exhaust stroke
Old 10-27-2009, 07:25 PM   #4
Bad99Olds
New and Improved
Bad99Olds's Avatar
I saw that and was wondering the same thing...
Old 10-27-2009, 08:02 PM   #5
WhiteV6
Wide Open Throttle
Those are numbers without manifolds. Probably the valve job on the .050 and .100" lift flow numbers.
Ben
WOT-Tech.com
60DegreeV6.com
Old 10-27-2009, 08:50 PM   #6
WhiteV6
Wide Open Throttle
Stock 3400 Intake = 111.4cc
WOT-Tech Strip Intake = 113.5cc
WOT-Tech Race Intake = 119.4cc
MMS Stage 2 Intake = 117.2cc
Stock 3400 Exhaust = 70cc
WOT-Tech Strip and Race Exhaust = 72cc
MMS Stage 2 Exhaust = 76.2cc
WOT-Tech Street/Strip heads outflow MMS Stage 2 and have more velocity on intake and exhaust.
Ben
WOT-Tech.com
60DegreeV6.com
Old 10-27-2009, 11:28 PM   #7
3500Alero
3500Alero is on a distinguished road
what size bore did you use? pipe on exhaust? clay on intake?
2004 Olds Alero 3400 v6 15.32 @ 88.69mph Bone Stock
1999 Olds Alero 2.4 to 3500 swap (running), Ported heads. totaled by a honda
2002 GAGT 3500 swap. parting out
1993 c1500 turbo 3100 swap 5psi.
1976 Cutlass 350 olds stock for now
3500Alero is offline   Reply With Quote
Old 10-28-2009, 10:59 AM   #8
WhiteV6
Wide Open Throttle
3.700" bore, 28", 1.650" exhaust tube, clay on intake.
Ben
WOT-Tech.com
60DegreeV6.com
