Old 08-31-2008, 08:52 PM   #1
irondiezl3
irondiezl3's Avatar
will pcm hurt my car
if i put the tuned pcm in my car with only having a 180t cold air and plugs, wires is it gunna hurt the car? i wanna get that before exhaust cuz its alot cheaper.
Old 08-31-2008, 09:10 PM   #2
itsbmw
I would doubt it, but I don't know how the PCM tuner actually works. I think nate's Alero has done it but I dont know what upgrades he has if any.
Old 08-31-2008, 10:57 PM   #3
NA the only thing you need to run an aftermarket PCM is a 180* thermo
Old 08-31-2008, 11:02 PM   #4
It's not a "PCM tuner," it's a brand new PCM that is tuned that you swap with your stock one.
Speed limiter removed
3-1 and 4-2 skip shifts
Transmission line pressure increased
Shift points moved (5800-6000rpms)
Fan turn on points altered as follows:
186 degree F Turn On
Fuel/spark adjustments as follows:
Enriches fuel delivery for critical problem areas
Provides a consistent power gain across the entire power band
Reduces spark retard (knock retard
There's nothing that would "hurt the car." You'll be fine. -_-
Old 08-31-2008, 11:52 PM   #5
irondiezl3
irondiezl3's Avatar
thanks for correction ion. some sites say ill need to do relearn and some say i wont who is right?
Old 08-31-2008, 11:56 PM   #6
you don't know until you turn it on but it's not like it's a big deal, instructions are even right on PFYC's page for the product
Old 09-01-2008, 12:08 AM   #7
irondiezl3
irondiezl3's Avatar
so if the car sarts then ur golden if it doesnt then u do relearn
Old 09-01-2008, 12:20 AM   #8
yup, and remember to run at least 91 octane, that's what it'll be tuned for
