Originally Posted by bryan213
i have a 03 olds alero. motor is in good shape so is the body ... the only problem is the transmission... iv been reading about the 4t60e transmission and its a stronger transmission then the 4t45e but the only problem is will it fit.. just like the factory transmisson???? thanks
What's wrong with your transmission that makes you think you need a 4T60/4T65?
or
What mods do you have done that makes you think your transmission isn't strong enough?
The 4T65 transmission doesn't just fit. You have to make it fit with a lot of custom work.
