Old 06-19-2009, 08:08 PM   #1
ALERO81
ALERO81 is on a distinguished road
Help
Ok I have owned my Alero (99 with 168,000kms)for a little over a year now car has been running great until last month or so .
first I need to understand how the traction control works in our cars
from what I can tell it tied into the fuel system some how ?? is this true
my 2nd question is my car has lost power there almost no pick up now, I have just put in new plugs what else would you replace? fuel filter is next
please help
ALERO81 is offline   Reply With Quote
Old 06-19-2009, 09:21 PM   #2
3500Alero
3500Alero is on a distinguished road
have you checked your fuel pressure ? how many miles are on the car?
2004 Olds Alero 3400 v6 15.32 @ 88.69mph Bone Stock
1999 Olds Alero 2.4 to 3500 swap (running), Ported heads. totaled by a honda
2002 GAGT 3500 swap. parting out
1993 c1500 turbo 3100 swap 5psi.
1976 Cutlass 350 olds stock for now
3500Alero is offline   Reply With Quote
Old 06-19-2009, 09:38 PM   #3
Blktrax
Blktrax's Avatar
Blktrax is on a distinguished road
The traction system works by comparing the ABS sensors to detect wheel speed and measures the diffrence between them in relation to the Vehicle Speed Sensor (VSS). If it detects a large diffrence it limits power, by limiting fuel to the engine. If you had a faulty ABS sensor or VSS, could make the Trac system get faluty signals and limit fuel.
However this seems unlikely, most instances on here, with bad wheel bearings and the ABS and Service Engine light on, dont usually have driveability issues uunless another system is also affected.
Why or how did it suddenly not run right, what changed, any indicator lamps on or had been on prior to it running strangly?
One Bolt at a Time.
Blktrax is offline   Reply With Quote
Old 06-19-2009, 11:50 PM   #4
ALERO81
No I haven't check the fuel pressure as I said before my car only has 168,000KMS on it (not Miles)
Old 06-19-2009, 11:54 PM   #5
ALERO81
There was a check engine light that came on but when I plugged it in I only got a emissions slow leak
its strange in the morning the car start with no lights on i can drive it for about 1 km are so then the light comes on !
Old 06-20-2009, 07:33 AM   #6
what code did it throw?
Old 06-22-2009, 10:15 AM   #7
zzyzzx
zzyzzx's Avatar
About 105,000 miles (168,000kms)
Old 06-22-2009, 10:17 AM   #8
zzyzzx
zzyzzx's Avatar
I'm also wondering if you still have the original wheel bearings in the car. I'm inclined to think that you have more than one problem. Maybe even wheel bearings and maybe LIMG. Check your oil cap!
