03-20-2006, 11:52 PM
I got my oil changed today, but the check oil light is still on and the alarm still sounds. Is there a way to reset it or something?
03-21-2006, 12:55 AM
Boost Guru
dont start the engine but turn the key to "on". open the driver door and take off the fuse panel cover. press the reset button either once or twice until you see the "change oil" light start to blink. then press and hold the reset button....the light will stop blinking, you'll hear 5 ping sounds then the light will turn off.
03-21-2006, 02:00 AM
^ He is 99.9% correct,
You actually have to hold the reset button and count to five, then push reset button once...(one of the warning lights will now be flashing), keep pressing the reset button to cycle the light till the oil change light starts to flash then HOLD the reset button until you hear a several chimes----> YOUR DONE !!
03-21-2006, 02:27 AM
Or you have to turn the key on and fully press and release the accelerator 3 times within 5 seconds and you'll hear a chime. My 2004 doesn't have the button.
03-21-2006, 07:48 AM
You sure about that?
03-21-2006, 08:20 AM
Originally posted by Coupe+Mar 21 2006, 08:48 AM--><div class='quotetop'>QUOTE(Coupe @ Mar 21 2006, 08:48 AM)</div><div class='quotemain'><!--QuoteBegin-Cliff8928@Mar 21 2006, 07:27 AM
Or you have to turn the key on and fully press and release the accelerator 3 times within 5 seconds and you'll hear a chime.Â;-) My 2004 doesn't have the button.
[/b][/quote]
positive...my 2004 doesn't have a button either...neither do the intrigues...this is the way you have to turn them off with the newer ones.
03-21-2006, 12:36 PM
I saw the tech do this after my oil was changed in FL
03-21-2006, 01:03 PM
Originally posted by double0alero+Mar 21 2006, 06:20 AM--><div class='quotetop'>QUOTE(double0alero @ Mar 21 2006, 06:20 AM)</div><div class='quotemain'>
[/b][/quote]
X3, I had to look in the manual to find it when we changed my oil as I thought there was a button too...lol
1.3l Renesis Rotary
03-21-2006, 01:07 PM
my manual still says to use the reset button...too bad there isn't one...i called my old work and they give me the heads up on how to turn it off.
03-21-2006, 01:47 PM
Kthx, Im not sure wether I have the button or have to do the gas peddel trick, but Ill take a look
03-21-2006, 03:07 PM
Ok, the poor whiteboy doesnt get it. I tried to find the button on my fuse box, but to no avail. The diagram on the inside of the cover said there was one, but I cant find it. Maybe someone can point it out to me...if I even have one? If not, as far as the gas peddle thing goes, just on right...not like,...on?
03-21-2006, 03:08 PM
just do the gas pedal thing...my diagram says i should have one too but i dont...i think they were just reusing that sticker cause they had so many left over...
03-21-2006, 03:23 PM
If I remember right, you said you have an 04, so do the gas pedal and I will bet it works.
1.3l Renesis Rotary
03-22-2006, 01:34 PM
the gas pedal aslo works on the 01's. mine has the habit of coming on, even though the oil is perfectly fine
03-22-2006, 01:36 PM
the pedal will work with all years
03-22-2006, 04:05 PM
Designated Drunk
not mine...the reset button dont work either lol
I'm baaaackk
03-23-2006, 08:09 AM
Originally posted by 2000_olds_alero+Mar 22 2006, 05:05 PM--><div class='quotetop'>QUOTE(2000_olds_alero @ Mar 22 2006, 05:05 PM)</div><div class='quotemain'><!--QuoteBegin-double0alero@Mar 22 2006, 02:36 PM
[/b][/quote]
well its cause your car is a pos
03-23-2006, 10:42 AM
Designated Drunk
Originally posted by double0alero+Mar 23 2006, 09:09 AM--><div class='quotetop'>QUOTE(double0alero @ Mar 23 2006, 09:09 AM)</div><div class='quotemain'>
[/b][/quote]
sure is
I'm baaaackk
