Old 09-20-2009, 10:26 PM   #1
Dual fuel, old school
This is the latest stage in this fuel upgrade, using a modified carb-type fuel block to feed the rails. Room is scarce even though the FPR can be located anywhere, braided hose got to be too bulky to deal with. This setup is different in that I routed the fuel through the FPR. The 1/8 pipe tap is not all that restrictive compared to a 6AN hose fitting, but better flowing would be a T-fitting to replace the brass bushing between the FPR and fuel block. That would place the FPR to the side and run the main fuel line directly to the fuel block. Downside to that is, adapters are needed for the T-fitting, requiring more room. The FPR could be tapped for a 3/8 pipe outlet, but I dont think it's necessary. There are only 2 hose clamps involved, and the short rubber hose pieces provide a bit of flexibility, isolate from vibration.
Old 09-20-2009, 10:44 PM   #2
awesome! looks good man!
Old 09-20-2009, 10:48 PM   #3
Thanks, I wish I was better at routing wires, though
Old 09-20-2009, 10:50 PM   #4
Cool man.
Looks pretty clean wire wise
Old 09-21-2009, 12:21 AM   #5
jabartram
AutoCross Alero
jabartram's Avatar
i have that same FPR, its a tight squeeze between that fuel rail and intake manifold.
