01-10-2011, 12:51 PM
what shop said about power steering pump
so my car started to growl i suspected power steering because i just changed both lines and the growl showed up. i bled the effin sh***t out of it still growls i think my pump was on its way out and this gave it the final push so brought it to a couple shops they said its deffinantly the pump and its causing the growl but with aleros even with a brand new pump and lines its going to growl for life? that cannot be true please tell me its not.
01-10-2011, 12:55 PM
That shop is stupid, find another shop.
Better yet head to a junkyard and get a pump and do it yourself.
01-10-2011, 12:56 PM
how could the pump groan for life, if its a new unused pump? sounds pretty stupid
01-10-2011, 12:57 PM
yea it didnt make sense he said its a mystery i hope hes wrong is it easier to replace pump and res all in one shot i dont mind spending twenty more for it in one piece im just afraid remanufacted pumps arent good?
01-10-2011, 09:11 PM
My car wines like a supercharger and I expect my PS pump to blow up at any time. Whatever though it's the first car I have had with PS so I already feel spoiled by it.
01-10-2011, 09:14 PM
my PS pump groans when its cold out. when it gets up above 50 degrees, you cant even hear it unless its at full lock.
01-10-2011, 09:35 PM
mine is dead silent all day, every day.
01-10-2011, 10:06 PM
ditto. Never heard my pump...
01-10-2011, 10:51 PM
I can hear a tiny bit of noise if I push on the lock, but that's just cause the pump is at it's limit, otherwise silent.
1987 Honda Rebel 450
01-10-2011, 11:01 PM
only time my pump was loud was when it was driver for a couple days without fluid
01-10-2011, 11:21 PM
Its air on it ... and it will go away just drive it.
01-11-2011, 03:17 AM
my pump makes no noise its noise inside car. but if you put your hands on the pressure hose youcan feel and tell thats where the sounds is coming from but its new. 2 shops couldnt figure it out dealer said maybe the line is touching metal somewhere but its been bled over and over and over plus from what ive read it bleeds itself over time its been 3 weeks
01-11-2011, 09:22 AM
There is more to it than just a bleeding. You have to turn the steering wheel from side to side a bunch of times. Also check to see if it's rubbing like the dealer said.
01-12-2011, 11:27 PM
brought to dealer dealer swears its the pressure line because i bought it after market said aftermarkets dont flow right he guranteed if i changed it out with ac delco noise would go away he was suppose to charge me 1 hour labor and he didnt plus he knew i was going to do it myself so its not like he was trying to get me to get it done by them i have to say maybe hes right and being honest.
01-13-2011, 02:21 PM
Is the high pressure line vibrating?
01-13-2011, 04:03 PM
I tried driving in circles in the snow and using the e brake and 2 mins later I lost power steering. At first I thought the wheels were stuck because of snow because this is my first car and first time I experienced no power steering. I dont know but would doing this really break the PS pump? Anyway, I brought it to the shop and said I had to have the PS pump replaced. First he said it would be a 2-3hr job $160. Then he called up for the part and said for my car it was $195. At the end the final price was $224 and he said the pump was also cracked.
01-14-2011, 12:25 AM
do our resivours have screens in them?
01-28-2011, 07:39 PM
Sounds like you got what you deserved.
01-29-2011, 12:28 AM
My Power Steering bearing just started to go out, I hear a small knock when car is idle, and it sounds like I have a SC when I accelerate, I'm not sure if the PS assembly has been replaced but I know for a fact the bearing is failing simply by the black streak across the inside of my hood and the click that is felt when you hold Ur skin against the PS reservoir when changing RPMS.
B4 Cleared Corners/Fog Light Removal
No More Cobalts - 2 12" Punch HE2's
1100W BOSS CHAOS Mono Amp
