60Wrms should be fine on a 100W speaker, the way i look at it is this, if you have a sub, or speaker that is 100RMS/200Max you can safely run it at 100 obviously, anything more takes a trained ear to hear when distortion occurs, most of the time you can get away with more. it all depends on wattage too and the kind of amp. you often get more than stated from small amps. i have a rockford 500bd, 500W RMS at 2 ohms, i have it wired at 4 ohms to a 600W sub, gain at half, the sub can handle 1200W max, i've bottomed this sub a couple times, so this amp is putting out almost double stated power, if not more.
to make toe story short, the 60Wrms amp should do fine.
