01-27-2012, 06:55 PM
⌘ Irish Pride
Double Bridging?
Ok, I just bought a sub, box and amp off this kid from CL
Here are the specs:
Power Acoustik PS4-800 4-channel
4 ohms: 85 watts x 4 chan.
2 ohms: 105 watts x 4 chan.
Bridged, 4 ohms: 210 watts x 2 chan.
Now I'm assuming the next bridged rating would be something like 260w x 2chan @ 2ohm..... Would this be right??
Also it is running to ONE Alpine SWR-1243d 600wrms, of which has 4ohm DVC.
Now, here is the big question, is it possible (or safe for that matter) to double bridge this thing??? The bridge is currently running off channel 3&4, but if I run bridged 1&2 AND bridged 3&4 and run them both together to the sub and wire that to either 4ohms, would this work? I've never heard of double bridging, but seems like it might be possible. I'm thinking it would be putting out around 500wrms x 1chan @ 4ohms.
Done lost my mind
01-27-2012, 07:39 PM
You wouldnt be able to double bridge the amp. Also, the amp most likely will not be stable at 2ohm.
01-27-2012, 08:25 PM
:S Running the wrong amp man
01-27-2012, 08:42 PM
should have gotten an amp 600watts rms or more. those type rs like power. i had 2 of them on a 1500 watt rms amp.
01-27-2012, 08:50 PM
or a class d or mono amp...
01-27-2012, 10:10 PM
⌘ Irish Pride
Yea, I'm planning on getting the MRX-100 but just wanted to see what I could do with the amp that came with it. I have 4 gauge now, but its crappy no-name wire from my old sub system. Will be upgrading to 2 gauge here soon
Done lost my mind
01-28-2012, 01:20 AM
I love my type R, good choice. ^and yes, putting more power to it makes a HUGE difference. Don't double bridge. You'll be fine with The single bridge set up for a while. Also for looking at new amps, check out the kenwood performance amps.
01-28-2012, 02:12 AM
Use the amp you have for when you get aftermarket speakers you can amp them, and yes kenwood is great my whole car is kenwood and it sounds so much better then most people i listen too, alpine is also great
01-28-2012, 09:39 AM
⌘ Irish Pride
I do have aftermarket speakers. All Infinity Kappa, amped.
Thank you everyone for your input!
Done lost my mind
01-29-2012, 05:30 PM
⌘ Irish Pride
So, after only a few days, I fried the amp that came with the sub. I failed to realize that a 4ohm DVC wires down to a final impedance of 2 ohms. The amp that came with it runs at 4 ohms bridged @ 210w.
Oh well!! I did some further investigation and found the Alpine MRX-M50 will be my best bet since it runs 500w RMS @ 2 ohms and the sub runs at 600w RMS @ 2 ohms. I will be getting some new Kicker 4awg wiring as well.
Anyone have any input on caps? I was looking at this one on amazon and it seems ok.
Done lost my mind
01-29-2012, 06:23 PM
Do not get a cap just do the big three upgrade a cap is a waste of money. just order more. power wire but i would go with 2 or 0 gaige then get a distrabution block and run 4gauge from there. that is what i have. for my alpine type r sub and it works great. the big three will really help i am still running a stock altenator and i am pushing 2 amps one alipne mpr1000 i got 2 years ago for the sub and a 600 watt amp for mids and highs
01-29-2012, 07:29 PM
4 Ga on the big 3 is plenty. Your negative running thru the chassis/unibody can only support around 150 amps anyhow.
You cant wire a 4 channel amp down to 2 channels @ 2 Ohms. They dont do it. I seen you learned that the hard way though.
