so i changed my tired over the weekend..since the winter is coming n everything...however...after i put em on...n i went out for the test drive...the low tire pressure signal goes on....i check the tire pressure...everything seems okay....but it still on...what did i do?
first thing, bud, if you want the rev name, you need to check out his standards. i'm sure that he would have used the search feature first. there are a billion and one posts on this.
the reset is located in the drivers side fuse panel. it's red. you need to push this one time with the car set to ON. the oil light should flash. push it one more time and the low pressure light will flash. now press and hold the reset for like 5 seconds. all done.
keep the change.
