02-24-2011, 12:36 AM
can you get into the cruise buttons?
lights just went out in the cruise buttons on the steering wheel. how do you open it to change the bulbs?
02-24-2011, 04:37 AM
all at once?? thats not a bulb
parts so far: 10000k hid heads and fogs, alpine INAW900, bluetooth, backup camera, alpine mrp-m2000, 18fi btl, 270amp mechman alterntor, 2 Redtop Batt's, all LED lights and color changing signals white/amber (every bulb other then dummy lights) and limo back 3 and 20% in the front and tinted tails
check out my car http://www.youtube.com/user/scott192
Well I know my car is female because she was bleeding for 7 days and didnt die!
02-24-2011, 09:12 AM
it is a very very small bulb soldered into the plate where all the electronics and switches are on (sorry dont know ho to call it in English)
At least it has been a bulb (under a magnifying glass u could see the wire) in my old '99 controls.
If u are certain that all other wiring is intact and working and only the bulb is burned out - u could perhaps solder a LED into it.
Thanks Julian
1995 Chrysler Stratus LX
2002 Nissan Primera with CVT
02-24-2011, 10:38 AM
so basically replace the entire piece does it seaperate from the steeringwheel?
02-24-2011, 11:03 AM
yes - its quite easy work. But u have to have the guts to handle your airbag.
I think theres a how to already on here
Thanks Julian
02-24-2011, 12:29 PM
That's funny, only one of the buttons has a light not working on my '99 cruise control.
The rest of them turn on or off normally when engaged.
02-24-2011, 12:56 PM
Yeah, the only light I've ever seen is the one on the left side that indicates the system is enabled. There is an indicator on the dash to show it's engaged.
Does your cruise control work? Maybe a more serious issue here, or even just a fuse...
02-24-2011, 01:08 PM
replace the entire assembly if its the switches. Cheap and very easy to do. around 20-30 bucks if i remember right when I did mine but I had the employee discount so it might be a bit more.
02-24-2011, 10:45 PM
you mean take the whole black piece off? and as for the lights all my buttons light up green and a few of them recently blew out the cruise works fine.
02-25-2011, 09:08 AM
You have to remove two bolts from the back of the steering wheel, remove the airbag, then you have access to the screws that hold the switches in place. Take those out (and disconnect the wires) and you can then work on the light (if its blown) or replace the switch (if its bad)
All things considered, not that hard. BUT you DO have to remove the airbag. If you have the cojones to do that. (nothing to worry about, but it terrifies some people)
02-25-2011, 04:45 PM
Thats what I said.
And a friend of mine had an accident with the seatbelt explosives in a Ford.
He was lucky that his hands were somewhere else - but it scared the crap out of him and burned the seat - that solved a bucket of water
Thanks Julian
02-25-2011, 04:53 PM
Its like google translator was hung over and didn't care about its job, for that post.
(not making fun of you, man. I know english isn't your first language) But fyi...that doesn't make one bit of sense. Start to finish.
02-25-2011, 05:17 PM
hupppsss -- kinda brain fart
I mean the little explosives that are in the seatbelt restrainers to tension them in a crash (maybe it isnt as common in the USA)
He took the seat, seatbelt and so on apart - and all of a sudden - BOOM the restrainer and the seat were on fire, thanks to the explosion.
poured a bucket of water over the burning seat.
Hope now its clearer what I meant.
Thanks Julian
02-26-2011, 12:17 AM
They're called a pretensioner. There's tons of vids on youtube.
02-25-2011, 05:19 PM
Very clear. However... i've never heard of those seat belt explosives.... ever.
Must be a euro thing.
02-27-2011, 06:26 PM
They tend to ohm out about the same resistance as speakers... so sometimes newbs tap into them when installing a speaker amp.. them POOF oh crap.
02-28-2011, 03:12 AM
Thankfully such stuff never happened around here, at least I didnt hear about it.
But again, Germans dont do much stuff on their own cars. If the OE didnt built it into the car, and 3 or 4 technical supervising organizations approved it - dont touch. Morons
Thanks Julian
02-28-2011, 02:15 PM
I heard in a lot of countries in Europe any aftermarket wiring needed to be black or something like that?
Don't remember where, but it sticks in my head.
02-28-2011, 06:01 PM
nope - not Germany - atleast I dont know it.
I choose my wiring color as close to OE as possible (with my limited colors)
Cause if all wires are black - thats gonna be pretty hard to diagnose errors.
as long as u didnt only built new grounds
Thanks Julian
Hybrid Mode
