you will have to pull the fender well back and reach right wehre your wiper fluid is. it works best to take off your tire and jack your shiz up, but i just did it by turning my wheel all the way left..it worked out fine, you don't need to cut anything or remove anything, other than that 20 mile long stock, restrictive bull shiz you pull out.
edit oh yeah, and mine seems to sound the best at about 2700 rpm....on that note, i have my pipe that goes into the filter and it is buried all the way in that think maybe less than a 1/2 inch of space from the inside top of the filter, will that cause a problem performance wise? give me someinput
