Old 02-02-2008, 12:42 AM   #1
How to?
Is it possible to realign the headlights.? im tired of my dims being brighter than my brights. i got new bulbs and everything. didnt fix the problem.. the highbeams seems to be aimed at the tops of trees which is rediculous :\
Old 02-02-2008, 01:51 AM   #2
Vinalero
Vinalero's Avatar
theres 2 adjustment screws on each unit, they are in the back of the housing on top of it. 2 black thing with white shafts.
Old 02-02-2008, 07:36 AM   #3
You need a "Torx" socket to do it
Old 02-02-2008, 08:03 AM   #4
also, make sure the bulb is locked into its housing correctly. if your lights are THAT far off, you probably miss aligned the notches when you twisted it into place...
