05-05-2011, 09:22 PM
#21
http://www.autozone.com/autozone/acc...ier=32416_0_0_ just plug one of theese in to where your sunroof fuse is, make sure you use the correct amperage fuses and run a wire to your headunits 12v power wire and you only need one fuse if you dont have a sunroof
05-06-2011, 09:29 AM
#22
Well I do have a sunroof do then what?
05-06-2011, 08:40 PM
#23
the fuse tap turns one fuse spot into two fusable circuits you use your original fuse in one position on the fuse tap and you use the other to fuse your radio.
05-06-2011, 08:44 PM
#24
OOOh ok I see, thank you. I thoughts what it looked like in the picture but wasn't sure.
05-14-2011, 07:29 PM
#25
So got the fuse tap from autozone but it says not to exceed 10 amps and the sunroof fuse i have is 20, is this still ok to use?
05-14-2011, 07:33 PM
#26
p.s. on my new deck there is one "sub-out" jack but my the wires on my amp have 2 plugs? do i just use the "aux-l-in" and "aux-r-in" still?
05-15-2011, 08:31 AM
#27
Nobody?
05-15-2011, 10:23 AM
#28
Screw it, just gona go for it.
05-15-2011, 10:26 AM
#29
you are saying for your sub output there is only one plug for an rca jack? well in order to power both channels on you amp you are going to need both rcas plugged in of course...just go to radio shack and get yourself a single male to double female rca splitter and plug that into the back of the HU...problem solved
05-15-2011, 04:47 PM
#30
I would assume the 10 amp rating is only for the added circuit and you dont want to connect your amp to an input on your head unit because the headunit sends the signal to the amp.
09-05-2011, 09:51 AM
#31
luckilero how did you make out?
09-05-2011, 10:21 AM
#32
Works great! The ONLY downside, and a slight one, is that in this set up the radio will only come on at the on or car started position and once you turn the key off the radio goes off. There is no more convenience of the radio staying on until you open the door.
09-05-2011, 10:30 AM
#33
that sucks. what year is your car? iv herd the 99s dont have to having anything special. least from what i read over on gaownersclub.
09-05-2011, 10:31 AM
#34
That's the retained accessory power feature...to keep that you have to use the chime module
09-06-2011, 11:17 AM
#35
Yeah, but I don't mind it. Mine is an 03. It will work fine if you just follow the how to.
09-06-2011, 07:57 PM
#36
well my car doesnt have rap anyways. my other 99 the door chims still worked wiht an aftermarket setup.
09-06-2011, 08:05 PM
#37
next question is what do i do about the antenna amplifier?
