Old 05-13-2005, 06:02 PM   #1
-Alero-
-Alero-'s Avatar
hey just making sure if the grand am rotors fit the alero rotors? i forget if they do, im confident they do. im getting new d/s rear ones and i wanted to be positive on this. also how is the installation? is it harder than the front?
AUTOBOT
Old 05-13-2005, 06:16 PM   #2
Oldsmopimp
yes, and no.
Old 05-13-2005, 06:30 PM   #3
-Alero-
-Alero-'s Avatar
so....they do fit and dont fit at the same time!?
AUTOBOT
Old 05-13-2005, 06:55 PM   #4
Oldsmopimp
u asked 2 q'z. If they would fit? and if the install was harder than the front?
Old 05-13-2005, 07:04 PM   #5
knowfear
i think what he meant was that yes, they will fit, and no, they are not hard at all. remove the caliper, and the brake pad mounts, pull off the old rotor, put on the new rotor, reinstall the brake pad mount, and the caliper and youre done. with the right tools (air tools etc..) its like a 20 minute job.
Old 05-13-2005, 07:07 PM   #6
Oldsmopimp
^^^^ si
Old 05-13-2005, 08:38 PM   #7
bigd6983
make sure that you have enough clearence on the inside of the rotor where it meets the emergency brake pads......mine was a little tight of a fit and right now i have minor minor binding which i need to pull off and sand down the inside of the rotor just a hair.......
other than that its the same as the front
Old 05-15-2005, 11:05 PM   #8
also the W-Body rotors are the same in the rear as well. (Impala, MonteCarlo Grand Prix)
Old 05-17-2005, 03:10 AM   #9
Spilner521
Boost Guru
Spilner521's Avatar
this can be avoided by not pulling the parking brake when changing the rear rotors. :P
Old 05-17-2005, 07:28 PM   #10
Ready for the next post
"Like OMG, I screwed up my brakes" :hide:
Old 05-17-2005, 08:20 PM   #11
-Alero-
-Alero-'s Avatar
............yeah cause i mess eveerything up when i do it :rolleyes:
because its not like ive done it before..... :rolleyes:
you'll realize one day its cheaper to do things yourself than to pay someone else for something.......also i hate to tell you but, no one can do a better job than yourself. (perfectionist)
also look at my engien compared to yours Ken. everything there has been installed be me or with help by a friend. i have never once taken my car anywhere to get it worked on...
AUTOBOT
