Ordering clevite bearings soon.. then need to find a deal on Wiseco pistons/rings ($450 new) Then tearin her apart to put it all in and boost with confidence.
spyhunter, $110 shipped lol. i got paid $100 from someone for helpin them out on a website design so basically out of pocket they only cost me $10. Not bad for a $350 retail.
Only thing is one of them spun a bearing, so it's scuffed a tiny bit, just need to have a shop clean it up. Hopefully the stock size bearing will work, if not, I'll just need to grab a bearing that's slightly larger.
