04-20-2007, 06:09 PM
B&M Shift Improver?
http://www.carcustoms.net/product_in...ducts_id=4 77
Just happened across this while browsing for performance parts. Anyone tried this guy on an Alero?
-Brad
04-20-2007, 07:15 PM
Southern Fly Boy returns
I havent tried it but I know it will firm up ur shifts quite a bit.
04-20-2007, 08:47 PM
I Have ONE NUT
I got mine from jegs and it might the best $53 I've spent on performance.
04-22-2007, 12:21 AM
[boosted 2.4L]
great product. simple install. i think it's 2 wires. comes with everything to connect. 3 settings- stock, sport, race
definately a plus for any car, stock or modified. it might even extend the life of a tired tranny.
04-22-2007, 01:36 AM
WOW nice find. Im looking 2 get one now Considering now that i changed my tranny filter and fluid plus the cold air i feel a good acceleration response but with this...Im getting one. Best tranny mod next 2 swapping for a 5 speed
04-22-2007, 03:11 AM
Sorry for being such an ass, but becoz of my bad english and the fact i'm new to all of the car matters(i'm 17, got my Alero just not a while ago) I didn't get what does this thing exacly do... Anyone can explain? Oh well... U don't have to bother coz in Israel those things arent allowed anyway, but i'll be glad to know.
04-22-2007, 12:37 PM
I had one and I think Scott think has his.
It's got 2 settings on it and what it does is it firms up shifts by closeing the shift soilend in the Tranny faster therefore causing less drop in RPM between shifts.
I used to have one but took it out when I put in the new PCM. They don't work well together
04-23-2007, 11:02 PM
Boost Guru
Yes it works awesome. Really firms up the shifts and makes the auto shift quicker than anyone can shift a manual.
...better than swapping to a 5 speed.
04-23-2007, 11:08 PM
I Have ONE NUT
and much easier.
04-23-2007, 11:41 PM
for 40 bucks u cant go wrong, whats it do plug into ur tcs or what?!?!
04-24-2007, 01:37 AM
Boost Guru
It has 2 wires that you splice in to 2 wires that plug into the tranny. Very easy.
04-24-2007, 01:43 AM
sounds pretty easy, but splice into what wires, ur tcs wires or ur lighting wires or?!!!??!
04-24-2007, 01:59 AM
Boost Guru
There's a big round plug on the front of the transmission itself. I forget which wires you need, but all you do is unwrap the wires going into that plug, splice in the wires from the B&M, and wrap it back up. Then you find a spot inside your car to mount the B&M switch. Like I said, very easy. Only thing is for it to work correctly you have to choose which setting you want when the engine is off. Flipping the switch either way won't do anything if the engine is already running.
04-24-2007, 02:14 AM
oh alright, nice lookin homie, Im definitely gonna buy that shit asap
04-27-2007, 11:43 PM
So if my shifter reads PRND321 it will work? I dont know hardly anything about GMs..
04-28-2007, 12:11 AM
Boost Guru
If your shifter reads PRND321 that means you have an automatic transmission. The B&M Shift Plus is a shift improver for automatic transmissions. So yes, the B&M will work for your car.
04-28-2007, 03:38 PM
I know that much. But in the web siote description it says this will only work for the 4 speed auto not the 3 speed. This product works on the 4 speed electronic transmissions. It will not work on the 3 speed hydraulic transmissions. If your gear selector reads P R N D 2 1, then THIS WILL NOT WORK FOR YOU
04-28-2007, 06:36 PM
mines messing up my tranny catches then looses 1st gear every 2 seconds its weird..but it workd pretty good b4 that. Just increases the fluid pressure in the tranny like everyone said.
04-28-2007, 07:13 PM
Well I just ordered one so when I get it and put it on ill post saying how things go and how well it works for me.
04-28-2007, 10:49 PM
Boost Guru
Right. It says that if what you have is PRND21 then it won't work. But what you have in your Alero is PRND321. There's 1st, 2nd, 3rd, and the D is 4th gear, also called Overdrive. All automatic Aleros have the 4 speed auto, so it will work on every automatic Alero.
I have it on mine and it works awesome...very noticeable difference in shift firmness and quickness.
