01-16-2007, 12:26 AM
Cold engine knocking?
I've started to notify something since the cold weather just arrive. When I start my car after it has sit for all night for exemple, The car at start rev at about 1600 rpm which is normal for a cold engine. The problem is that I hear a knocking sound from the engine for a short duration until the car gets back to idleing at around 1100 rpm.
Is this a common sound at a cold start?
01-16-2007, 02:23 AM
is it more of a ticking?
01-16-2007, 03:55 AM
I can feel a vibration when the "knocking" happens. after lets say 45 seconds it disapears.
01-16-2007, 08:56 AM
Designated Drunk
what kind of mileage have you got?
I'm baaaackk
01-16-2007, 11:54 AM
Mine ticks too, but the knocking, any lights?
01-16-2007, 11:57 AM
Mine ticks and in the cold it is even worse but nothing to worry about. It seems GM engines do this a lot.
??,??? km
??,??? miles
01-16-2007, 12:02 PM
once again, I'm going to go with "Move South"
01-16-2007, 12:27 PM
mine ticks also in the cold. in my beretta, the engine always ticked, but its up to 210,000 miles and still going.
01-16-2007, 12:49 PM
the 3400 is known for its "piston slap". i have a loud tick or knock for the first min until the pistons warm up enough to fill in the slight gap. the GM guys tell me that the pistons are a bit too small for the cylinder. there is a fix, but its only temporay. After that it goes away and sounds fine.
Its just one more thing you will have to live with. Ive had the piston slap since I go the car at the 40,000KM mark. Its a 2000. now has 82,000KM.
01-16-2007, 01:42 PM
theres 2 different ticks really, theres the piston slap and lifter ticks. piston slap = normal. lifter tick = bad. lifters are damn loud
01-18-2007, 04:18 AM
Nah, its not lifters. And maybe knocking isn't the right word to use. It's like something is loose inside the engine. I have 107 000km (around 68 000 miles)
No lights comes on.
to make it short:
-Start engine in the cold
-1600 rpm rev
-each time i hear the noise the engine's revolution varry slightly btw 1500 and 1600
-45 seconds later, revolutions are under 1500 and noise is gone and it's running fine.
I'm guessing its only the engine that is too cold. I was just wondering if ppl with the 2.4L were getting something similar.
Also, does anyone have a sound clip of his 2.4? I would like to know how it sounds to see if it compares to mine. thank you
02-06-2007, 07:10 PM
same w\our f-150. it knocks unitll it warms up a bit a the pistons swell some. its common. vibration could also be if u were plowing snow. that happens to me a lot after going thourgh a couple small drifts (halfway up door). snow get stuck b\t engine and fan and knoks the fan out of wack.
03-24-2008, 04:46 PM
