02-21-2008, 12:08 PM
best damn wires!!!!!!!!!
i Want The Best And Biggest Wires Out There Who Knowes Where To Get Them?
02-21-2008, 12:17 PM
Summit Racing sells 1 gauge battery cables, will that work?
02-21-2008, 12:18 PM
climb pole
cut power line with heavy duty cutters
fall off pole
if still alive, pick up wire and use it for your needs
02-21-2008, 12:24 PM
would you like to be a little more specific on what KIND of wires, before this gets any sillier?
example: spark plug wires, speaker wires, wire spoke rims, telegrams, etc......
02-21-2008, 01:00 PM
Lmao Can I Be Any More Retarded. Im So Sorry I Should Be Kicked Out For This Wowwwwwwww. Ive Had A Rough Day Guys. Spark Plug Wires. I Know Bigger Doesnt Matter But I Still Want The Biggest And Best!!!!!!!!!!
02-21-2008, 01:14 PM
Fewer exclamation points dude. Plug wires are not that exciting. Get msd's from summit racing.
02-21-2008, 01:19 PM
Trying To Help
msd autozone buy for pontiac
03 OLDS ALERO
02-21-2008, 01:22 PM
taylor 9mm if you just have to waste the money.
I'll say this again.....ANY aftermarket ignition components (coils, wires, plugs, etc) will not make a noticeable difference (other than placebo effect) until you get into much higher HP range. Unless your original equipment was faulty.
I've built the hell out of my turbo system twice now, can smoke most of the stuff on the streets around here, and I'm still using my OEM coil packs and plug wires.
02-21-2008, 01:31 PM
i totally agree withyou i dont think bigger better wires do a damn thing for performance!!!! but i like the colors and its not really much more than factory delco or even bosch so id rather just get them 9mm sounds good ive looked everywhere and i dont see them and why for pontiac???? why not for an alero?
02-21-2008, 01:49 PM
Trying To Help
when i wen to auto zone they did not show msd wires for alero but the did show for pontiac grand am
03 OLDS ALERO
02-21-2008, 05:01 PM
Special Agent
I dunno what motor you have, but if it's the ecotec, then you don't even have spark plug wires.
THE Ohio State University!
02-21-2008, 05:44 PM
Be careful, some come "Assmebly required"
02-21-2008, 06:18 PM
AMEN like my accels LOL
02-21-2008, 08:22 PM
OEM spark plug wires and coil packs work fine.
If you absolutely must spend money on wires that won't make a perceivable difference, I recommend Magnecor.
