Old 06-13-2006, 09:14 PM   #1
dbizz23
dbizz23's Avatar
dbizz23 is an unknown quantity at this point
Send a message via AIM to dbizz23
so i go to work this morning and i was sitting in the parking lot smoking a cigg bumpin to a little music before a day of hell. I get done and turn my car all the way on and all it does is click, doesnt start up or anything. Me and my co-workers try to jump it, still nothing. What are the possible problems
starter?
alternater?
any info would be appreciated.
Pluggin Fresh Holes
dbizz23 is offline   Reply With Quote
Old 06-13-2006, 09:19 PM   #2
AlbinoMonkeyRat
Let's Play Army!
AlbinoMonkeyRat's Avatar
fuel pump is another option...
Old 06-13-2006, 11:48 PM   #3
scsralero
scsralero is an unknown quantity at this point
is it turning over at all or just the starter clicking. cause it could be just something simple lik a bad conection on your battery, on my olds cutlas my battery died tryed jumping it nothing i moved the positive side post a bit and it started right up. hey you might get lucky
scsralero is offline   Reply With Quote
Old 06-14-2006, 08:07 AM   #4
Coupe
Start simple:
Check battery cable connections
Check the battery (get it tested)
Check alt (get it tested)
Can you hear the fuel pump prime?
Old 06-14-2006, 11:22 AM   #5
FartCannonAlero
this happened to me yesterday, i hooked my ipod up to my radio and was listening to it for a little bit and then i went inside real quick and came out to head to work and nothing happened..just a click, so i checked the fuses under the hood and my R/H Bec Batt fuse #3 was blown all to hell...replaced it and everything fired up...
Old 06-14-2006, 12:33 PM   #6
dbizz23
dbizz23's Avatar
thanks guys...i'll try to see if my connections are tightened cuz this has happened to me before. The last time my positive bolt was almost completley out of the battery. So i hope it's that.
I was listening to music and then tried starting my car and all it did was make a click that's about it. i dunno i'll go see and post about it later. Thanks
Pluggin Fresh Holes
Old 06-14-2006, 06:15 PM   #7
dbizz23
dbizz23's Avatar
so i checked my connections everything seems to be alright. tried starting it.........Nothing still. the local autostore wants 70 bucks to run a dyno on it just to see what's wrong which is rediculous. It's pretty wierd, when i turn it on the system and my interior neons come on, but my dash lights don't. i don't know what's up with this thing.
any more suggestions anyone? i really dont want to spend 70 dollars on something that could be a quick fix. thanks
Pluggin Fresh Holes
Old 06-14-2006, 07:58 PM   #8
scsralero
try that^^^^^
Old 06-16-2006, 06:46 PM   #9
dbizz23
dbizz23's Avatar
ive replaced all the fuses and it's golden...thanks everyone for your input.
Pluggin Fresh Holes
