10-23-2008, 03:06 PM
#41
Thread Crapper
ok, new BCA bearings in hand.
i get to install them tonight.
we will see if this fixes it.
Originally Posted by Ttop191
10-23-2008, 04:43 PM
#42
ok... so... update?
you've replaced brakes/bearings and cruise is still dead?
10-23-2008, 05:27 PM
#43
Thread Crapper
no, i will be installing the bearings tonight...
update in the morning..
it pisses me off.
bearings were, i thought, fine.
rode down to randy's and they started going..
we will see if that has been the issue the whole time...
10-29-2008, 02:53 PM
#44
Originally Posted by 01silveralero
try to hold down your button while on the highway thats wut i had to do in my silver alero. stopped working after i had the whole steering and rack and pinion replaced.
ahhh.thats why my wifes won't work...thanks..
01 Alero GL 3.4 no mods.
03 2500 cummins turbo diesel.to many mods to list.
10-29-2008, 03:18 PM
#45
update?
10-29-2008, 03:40 PM
#46
Gone but not forgotten
ok here is my issue not to thread jack..but my cruise control works however the light "cruise" and the other lights (resume, cancel,etc) would not light up..the master on and off light is on...just the words are not lit...also my 3rd brake lights is illuminated dimly when its night without the brakes being pressed...anybody have an idea??
10-29-2008, 03:45 PM
#47
i'm pretty sure the words are just painted on, they don't light up....
and as for the 3rd brake light... sound like you have some power backfeeding through to that light. i'd check to see if any wires are touching/make sure the contacts are all clean (not corroded)
11-14-2008, 05:38 PM
#48
Thread Crapper
update?
ok, i got one side done a few weeks ago. / no change
have not had time till tonight to do the other side.
update monday morning...
11-17-2008, 12:24 PM
#49
Thread Crapper
yeah.
both sides done.
no change.
no cruise and abs still fux0red
03-18-2009, 04:37 PM
#50
Thread Crapper
ok, so,
a rundown...
replaced both front hubs
replaced both front calipers
replaced abs servo
i have SVS, abs, trac light, the red brake light, low washer fluid and change oil lights on...
so,
no abs
no trac control
no cruise
anything else i can look at????
p.s. yes, i know how to fix the last two lights... hahah..
03-20-2009, 10:31 AM
#51
Thread Crapper
03-20-2009, 10:53 AM
#52
Originally Posted by black
ok, so,
a rundown...
replaced abs servo
so,
no abs
no trac control
no cruise
PCM??
05-06-2009, 04:44 PM
#53
Thread Crapper
how about transmission speed sensors?
05-06-2009, 06:04 PM
#54
I have a cruise module available, if thats all you need....
10-25-2010, 02:29 AM
#55
my beretta did this it sounds weird but put your ebrake on till its just bairly engaged now hit up reverse and start moving back add more and more too the ebrake and gas untill it almost locks up and then a nice hard stop goin forward and it cleans / aligns the sensors no clue how but seems to work
parts so far: 10000k hid heads and fogs, alpine INAW900, bluetooth, backup camera, alpine mrp-m2000, 18fi btl, 270amp mechman alterntor, 2 Redtop Batt's, all LED lights and color changing signals white/amber (every bulb other then dummy lights) and limo back 3 and 20% in the front and tinted tails
check out my car http://www.youtube.com/user/scott192
Well I know my car is female because she was bleeding for 7 days and didnt die!
02-12-2011, 11:11 AM
#56
My cruise only works when I hold down the cruise button as well, must be a common issue, I ended up just jamming a screw to hold it down and then put some epoxy on the underside where it is not seen to hold it in the on position and removed the screw after it dried.
02-17-2011, 02:33 PM
#57
Thread Crapper
thank you.
the car made it to the shop this week.
it has sat for months.
gave up on it.
never even got to put the osv kit on.
lets see what the shop has to say.
04-01-2011, 04:24 PM
#58
Thread Crapper
thinking of it now, this makes total sense.
might not of went out right after i put the leds in.
http://www.aleromod.com/forums/showthread.php?t=33695
spent $1500 replacing anything to do with this s.h.i.t.
FUUUUUUUGGGGG
04-01-2011, 04:35 PM
#59
Thread Crapper
my first post on this issue was back on 02-01-2008, 10:08 AM.
my car sat for a year now.
went to go get plates, azzholes at the dmv said that i would have to pay the full price even though i have not had the damn car on the road for the past year.
i need beers.
