Old 03-04-2010, 12:24 PM   #1
wearetheromans85
wearetheromans85's Avatar
wearetheromans85 is on a distinguished road
starts then shuts off immediately
so sometimes my car will start then shutoff immediately. bypassed passlock 2 years ago. this didnt start happening until 4 months ago when it got cold here. also when this happens no lights come on when ignition is turned to any position dash lights, mirror lights etc. bad batt or something else?
wearetheromans85 is offline   Reply With Quote
Old 03-04-2010, 12:57 PM   #2
check all grounds and power connections to the fuse box..
Old 03-20-2010, 08:40 PM   #3
2000aleroff
2000aleroff is on a distinguished road
does it idle?
2000aleroff is offline   Reply With Quote
Old 03-21-2010, 02:27 AM   #4
Ign switch? Battery is OK otherwise it wouldn't crank.. which it must since you say it tries to start.
Needs more info... no lights coming on is a power delivery problem in the "run" circuit. Catch it when it doesn't work and start checking @ the ign switch "run" power wire. Then work your way out.. my guess is it has an issue before it branches to all the things that are "hot in run" at the fusebox.
Obviously the start/crank circuit is working.
The part where it starts briefly is just residual gas that may have dripped slightly from the injectors most likely (had a GP with no injector pulse that would do that when it sat overnight).
Old 03-21-2010, 11:33 AM   #5
check the altenator does the car do anything else weird when you start it. maybe the fuel pump can you here the fuel pump.
Old 03-21-2010, 11:44 PM   #6
WhiteV6
Wide Open Throttle
WhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond reputeWhiteV6 has a reputation beyond repute
Sounds like VATS to me. I just dealt with it today and had the same problem when it was set to PWM instead of Linear in the computer. Not sure how it can be disabled and come back on however.
Ben
WOT-Tech.com
60DegreeV6.com
WhiteV6 is offline   Reply With Quote
