12-29-2004, 10:54 PM
#21
Senior Member
Originally posted by VTOLDS@Dec 29 2004, 10:49 AM
They make a manual trans for the 3400? I thought they didnt.
they dont
now sporting 3 pedals
<img src=\'http://invision.aleromod.com/uploads/post-25-1071111759.gif\' border=\'0\' alt=\'user posted image\' />
12-29-2004, 10:57 PM
#22
Senior Member
Originally posted by germ@Dec 29 2004, 03:04 PM
depending on which manual tranny you go with, wont you have clearance issues with the xover and bellhousing?
btw, not a bad mod list you have for yourself.
and how are you going to hook up a turbo to that or are you going S/C
there is more room than there is with the auto actually.
and I'm still planning on using a whipple 1600AX supercharger
12-29-2004, 11:02 PM
#23
Senior Member
Originally posted by Final-Reality@Dec 29 2004, 08:03 PM
Thats a lot of hardware... those head ports look a lot better than stock....you just need a proper cam to go with them :P
:cheers: good luck with it, assembling is the easy part, tuning is the hard part :P
cam is on order and with any luck should arrive in about 5-6 weeks
make no mistake there is nothing easy about what I'm doing
tunning wont be that bad really
I'm investing in a wide band O2 and she may even be broke in on a dyno.
hardest thing is my R&D
I have sooooo much time wrapped up in this allready just finding part or having them made
12-29-2004, 11:04 PM
#24
Senior Member
Originally posted by SilverBullet256@Dec 29 2004, 08:32 PM
except a turbo would be good with the manual tranny so only he knows :thumbsup:
not as good as you would think
I've experienced close to this platform with a manual and sc and its a great combo
12-29-2004, 11:47 PM
#25
ahh the good ole supercharger, i still cant decide which route to go, better experiences w/ superchargers over turbochargers? i know the benefits of both but actual experience is better than any knowledge found in books...btw thats some hella custom work bein done!
12-29-2004, 11:54 PM
#26
Senior Member
I like instant power.
turbos are cool and I still want to play with one some time. I just cant stand lag. and turbos still take power to make power, but there is no way arround the exhaust restriction they create. There are ways to lessen drag on the engine from a supercharger.
that and too many people have turbos arround here
I've never owned one and the sound of them is old to me.
I figure I'm taking a car that gets little respect on the streets and wiping the smerk off their face, I might as well use a power adder that gets little respest.
not many people have messed with twin screw sc's
they are fairly new to the automotive industry. but what I've seen I love.
12-29-2004, 11:59 PM
#27
Damn, that's one hell of a project. Good Luck!
#28
ahh good point i totally overlooked! i know u were or are working on a supercharger kit for the 3400, is there any chance in the future for one to go on the ecotec?
12-30-2004, 12:06 AM
#29
uhh i believe there are plenty of turbos and supers for the ecotec. the ecotec has the biggest aftermarket.
also, springs is that a dual friction clutch?
AUTOBOT
12-30-2004, 12:07 AM
#30
Senior Member
nope
12-30-2004, 12:11 AM
#31
AUTOBOT
12-30-2004, 10:37 AM
#32
John,
Nice to see you are finally getting to the finish line on all the work you been putting into it.
Did you end up oversizing both valves? and by how much?
I hope TOG's new ceramic coating is better than what they used to use. The old coating, or at least the batch I got mine from, seemed like it had impurities that caused minor rust.
12-31-2004, 04:14 PM
#33
just came to mind, are you rearranging the power band and to what numbers? just curious how that works cause it still baffles me how that can be done on an engine....im sure this has to be done but thought i would ask anyway
12-31-2004, 04:17 PM
#34
Originally posted by springs fastest alero+Dec 29 2004, 11:54 PM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (springs fastest alero @ Dec 29 2004, 11:54 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-wy3134@Dec 29 2004, 09:47 PM
they are fairly new to the automotive industry. but what I've seen I love. [/b][/quote]
a screw supercharger...isn't that what the millenia S's had? that was one powerful engine for being 2.3L.
i was thinking the same thing, i see v6 headers, a clutch, flywheel.......awesome, to bad gm only put a stick to the smaller engine, alero could have been a pretty fast car with a 3400/5 speed
2001 Alero GLS - Sold!
12-31-2004, 06:08 PM
#35
Senior Member
Originally posted by Alerosince99@Dec 30 2004, 08:37 AM
John,
TOG should warranty your headers
if you want the new coating let me know
I can have yours redone in the new stuff.
intake and exhaust valves are lager but not by much. not sure the exact spec.
we went with another company since manley took so long on the last set of heads
01-02-2005, 03:51 AM
#36
I am trying to rebuild my engine and was wondering about what works in terms of upgrading engine internals on 3.4L
I am looking for:
Camshaft and its specs
Valves and their specs
Valve Springs & Retainers and their specs
Rocker Arms and their specs
Pistons and Rings and their specs
Rods and their specs
Lifters and their specs
I am also wondering how much over on bore I should go and about the heads. Can you please post some recommended engine internals specs as well as vendors? Thanks.
01-02-2005, 04:20 AM
#37
Senior Member
JE is who did my pistons they are totally custom being that my motor is now stroked
rods are modified small block chevy
you cant bore the engine too much because stock its pretty close to max.
www.60v6.com has some good info
www.j-bodyperformance.com has some internals that will work
much of what I've done is custom, one off, or modified from another application
01-02-2005, 11:02 AM
#38
01-02-2005, 02:32 PM
#39
That has got to be thee ugliest carpet I have ever seen.
Nice car parts, though B) .
01-02-2005, 06:39 PM
#40
Senior Member
I've seen worse but its my parents house I dont care
