09-19-2009, 12:49 PM
Missing after installing new coil packs
I'm not too worried right now, I think it's a "learning curve" thing.
I replaced the coil packs this morning (olds ones were rusted out on 4 of the 6 termails) and it was really easy. I didn't replace the little gaskets thou. The one's in there were fine.
Car starts up a lot better, and was idleing a bit high (1000 v 785) but that has since settled down to about 800 now.
I go on it and as soon as it hit 5 grand, it missed. The tach jumped to 6200, then 6600 I did it again, and it missed at 4500 and jumped to 5500. When I first drove it after replacing the packs, it missed at 1200 and shot to 2250.
After the miss, I got home (30 seconds after the miss) and damn did I smell a lot of fuel. Not raw fuel, but defently running very rich.
When I replaced my MAF, it had a pretty big learning curve which included a transmission shift from park to reverse which could have broken a mount on a CAT backhoe engine, no lie
Well I'm off the the car graveyard now to see if I can find parts from my 330 Olds motor.
09-19-2009, 12:52 PM
tht sucks good luck finding the part
I am beyond help...
09-19-2009, 01:14 PM
did you replace wire? if the posts were rusted they were probably rusting with the wire. And you broke that connection. Idk it's just a guess, probably not the problem. But just start small and work your way deep? You could also have the ignition module checked
09-19-2009, 01:54 PM
Well the problem has just gotten 50 times worse.
Normal driving now is plaged with missfires. I pulled over in a parking lot and wiped off all the electrical grease I put on thinking that may be the problem. It didn't miss too much after about 5 miles, but it did try to stall 2 times while sitting at a light
eff it. I'm putting the old coils back on.
09-19-2009, 02:54 PM
Is the service engine light on yet?
09-19-2009, 03:46 PM
you still havent replaced your ignition module have you.....
if its not the plugs not the wires, not the packs.....you look at the ignition module....
Moderator edit: Okay, things may have gotten out of hand in that other thread, but don't make it worse by being a dink.
AUTOBOT
09-19-2009, 03:53 PM
/\/\ it is a possability but rather then just swapping it with a new one. Take it out and run it to autozone for a free test
09-19-2009, 04:53 PM
check/replace the ICM??
had a major misfire replace wires/plugs/coil packs and nothing changed.. brought the ICM in to have it checked tested fine but I replaced it anyway.. low and behold car runs perfect again.. go figure
You want more power? You Need MP Racing!
"Now drink with me deeply of the bourbon, scotch, and rye until such time as we are fighting drunk. Then we shall find, and beat the a**es of, the nonbelievers who ruined my feast" -Alvis
09-19-2009, 11:28 PM
isnt that what i said?
AUTOBOT
09-19-2009, 11:33 PM
Its Beer Thirty
Thats what I read.
Originally Posted by Daytona
09-19-2009, 11:39 PM
Originally Posted by rustyballs_69
Thats what I read.
i said it on your last thread as well Ken....it was the final post, its down at the bottom of the 3400 threads
AUTOBOT
09-20-2009, 08:05 AM
Did you undo the battery for about 15 minutes to reset the computer?
09-20-2009, 03:28 PM
So granted I don't have the # of posts alot of the members on here have. But I have been undercover on aleromod since April of 07 and I'm beginning to think -alero- is a real d-bag. Why come on to a car specific forum, ask a for help, talk back to everyone trying to help then, be a royal ass to the other members facing a problem.. WTF grow up
09-20-2009, 04:46 PM
Enough crap. next comes warnings.
09-20-2009, 10:39 PM
As for the ICM, I'm not going to just go replace a $300 part on a whim. I know it's an easy swap, but for $300 I'm going to make damn sure that's the problem first.
Out of all the reseach I've done v. the symptoms with my car, it's either the ICM or injectors.
09-20-2009, 10:42 PM
i can do this at my local AZ:
i can go in, and im pretty friendly with them, they let me try the part and if its the problem, i buy it, and if its not, i can put it back. ask if you can try a new ICM
09-20-2009, 10:45 PM
Could anyone post a pic of the exact part (ICM) you need to swap to test it? I'm drawing a blank on this. Maybe I can find one laying around.
09-20-2009, 10:48 PM
Part number 3
09-20-2009, 10:55 PM
Part number 3
I think I found it, I'll upload a pic here in a few minutes....
09-20-2009, 11:05 PM
It's in this assembly, huh? This has been laying around a few years, got it in trade from Kwhauck. I can disassemble it further, if you want, check it out a bit more......
