Old 11-25-2003, 05:38 PM   #1
Wildman
Wildman's Avatar
Wildman is an unknown quantity at this point
Ok, so when I push my hazard button, it pushes right into the dashboard. So I got the new housing that the switch slides into from behind the dashboard. How do I get the old one off. I was only able to get to one of the three screws. The other two are very tough to get to and almost impossible. Do I have to remove the center vent to get to the screws on the bottom and other side of it ? Please help!
CAI - Borla Cat-back - S&S Headers - DHP - AFPR
Wildman is offline   Reply With Quote
Old 11-26-2003, 09:02 AM   #2
2kalerorocket
Hazard Switch Replacement Instructions.
This should help you out.
Old 11-26-2003, 09:23 AM   #3
Alerosince99
Just out of curiosity is the black piece that surrounds the button broke? I have had this go bad on two aleros just curious if its the same thing or not?
Old 11-27-2003, 01:03 PM   #4
Wildman
Wildman's Avatar
Yeah, thats exactly the piece. Thanks for the instructions, they will help a bunch. Any tips on getting that vent off though ? i pried at it with a putty knife and it couldnt come off
Old 11-28-2003, 07:20 AM   #5
2kalerorocket
ok here is what you are looking at. three tabs on the top and two compressable clips on the bottom. To remove it the manual tells me to push down the three tabs on top and get the top out first. but the three times I have removed the vent it has been different each time top bottom or rip it out occured. I would guess if you used a putty knife on the bottom clips it should slide out. you just have to play with it a little. I will see if I can find my broken one and take a pic of the top and bottom so you see what you are up against. That one did not break because I was taking it out, it happened when my girlfriend and I were.. well we'll just leave it at that.
