11-09-2011, 09:02 PM
HID diag help. please
so heres the deal. i bought some used HIDs from one of the guys on here. dont remember the brand but i remember that each ballast has a black box on the wires going to the light (the black box is NOT the ballast).
so the issue. when i first got the kit and had them installed i was like "DAMN". im noticing now that one bulb is a slightly different color then the other and the intensity feels not as bright after a few minutes of having them on. iv got the hids wired in series-parallel with a relay using battery voltage and OEM headlight wires on the drivers side as the switching circuit for the relay.
how can i tell if i have a bulb issue or a ballast issue?
11-09-2011, 10:06 PM
⌘ Irish Pride
Are you only using the factory wiring, or are you using a wiring harness that feeds off the battery? When I got my first set of HID's, they were pretty good for a while, but then on of em started dimming, and flickering and ultimately the ballast just stopped working. I got my second set, and used a wiring harness, and have not had any problems at all
Done lost my mind
11-10-2011, 07:04 AM
i made my own harness going from the battery to the ballast
11-10-2011, 07:21 AM
switch the ballast from right to left and see what happen...
11-10-2011, 07:23 AM
well for the most part the intesity appears equialy dim. but i can atleast do that to see if its the cause for my color issue
11-11-2011, 01:10 PM
you bought a used setup, there is a possibility you found the reason why it was sold off to you...
01-28-2012, 11:50 AM
so bringing this thread back. if been fighting with one side flickering a lot. i know hids will flicker when they dont have enough voltage. so does this mean im not getting enough voltage to the control box or is it possible to have risistance in the wires going to the bulb causing the lights to flicker?
01-28-2012, 12:53 PM
I've had my kit in for about a year now, with no problems at all. Occasionally, I'll have one bulb not fire up for some reason, but a quick turn off of the car and restart fixes the problem. As far as dimming, you could have ballasts going bad, but could also just be the bulbs going... Flickering usually indicates the bulb is going out. They use HID bulbs for intelligent lights, and they do the same before going out, both flickering and dimming.
01-28-2012, 01:05 PM
well for now problems fixed. i checked the passneger side power connector for the box while i could get it to flicker and had 11.7vs. compared to the drivers side and had the same voltage (cars off mind you). also when i pulled the connector a part it was full of water. apparently xtreme only puts weather seals on one side of the connectors and not the other. packed both sides full of dialectric grease and retested. still flickers. noted passenger side connector was warmer then drivers side. tried to get the terminals out but couldnt figure it out so for the time being i removed the connector all together and spliced the wire. been working flawlessly for now.
01-28-2012, 01:15 PM
⌘ Irish Pride
I believe that black box is the ignitor. I know on the Raptor ballast (DDM) the ignitor is in the same housing as the ballast. On the slim digital ballasts, they have a separate black box which I'm almost positive is the ignitor.
As for the color problem, I'm not sure. Are they matching ballasts? I'm currently running one slim digital "9006" ballast and one slim digital "D2S" ballast. I have matching bulbs, but one is a VERY slightly different color than the other.
Your wiring harness should be fine as long as you used some decent gauge wiring.
Done lost my mind
01-28-2012, 01:19 PM
for now i could care less about the color difference. once i get the rust fixed im looking into doing high/low/fogs hid. they are the same balasts. theres two boxes on each hid. one is a big silver one with the xtreme decal, the other is a little black box on the bulb side of the harness. so far so good though.
01-28-2012, 01:43 PM
I had an issue with my first HID kit getting water in it... Really sucks... I'd probably replace the ballasts with the DDM Tuning slim ballasts. Haven't had any issues, and they seem really water tight.
01-28-2012, 01:51 PM
^^ That's why I took my HID's off
02-09-2012, 06:19 PM
well making progress. I swapped bulbs from left to right and my color issie swiched with it. Last week ordered new bulbs from xtreme and ill continue to use the same balests untill one of the gives out. When i upgrade high beams ill give ddm a try and go from there. So tonight my bulbs arived (8000ks) and hooked them up. Looked great except one side litterly changes colors as if a switch was turned on and then goes out after 3 switches. Swapped bulbs left to right again and it followed so iv left a message and hopfuly will get this resolved tomorow
02-09-2012, 06:30 PM
Probably just a bad bulb. That happens... To be honest, I'd go with DDM tuning.... I know it's been said before, but they really are better to deal with.
02-09-2012, 06:41 PM
oh im sure they are and when i go to buy a kit ill go to them next. I just cant afford a complete kit right now and i didnt really want to mix and match brands. Looked like ddms connectors were different from xtremes too. And iv got to have a bad bulb because i put the same bulb on two balests and had the same problem on both.
02-09-2012, 08:01 PM
yeah, it's just a bad bulb... I got one of those on my HID projector lights on my bike, but can't seem to find replacements for them....
02-28-2012, 06:48 PM
well i FINALLY got a bulb bank tonight... mothaeffer did the exact same thing. swapped bulbs from one side to the other and still did it!. seems to have ironed itself out at this point however... one more issue and its all going in the garbage and ill be visiting ddm.
02-28-2012, 06:52 PM
lol that's so weird...
02-28-2012, 06:54 PM
im honestly not doubting i got sent the same bulb back. at one time it has a "two in-two out" harness and you can see where they cut the grommet off the harness but left parts of it still on the wires... then shipped it to me... "umm.... i still need the other harness a-hole. plus they didnt return my receipt... glad i copied that before sending it
