12-09-2008, 03:10 PM
#181
I never said I was dead set on it. If it doesn't fit with the turbo on it I won't get it.
The top mount is cheaper, the Vulcan Turbo one is $400 (Add 50 for external wastegate flange)
I do, however, like the way the top mount looks. Its cool
12-09-2008, 03:42 PM
#182
Originally Posted by Cliff8928
How driveable is the twin disc? Is it easy to modulate with good pedal pressure?
You'll hate it, and grow some strong leg muscles. It's very driveable once you get used to it. Then again I've had to drive a few cars w/ twin disc setups. It's seriously like an on/off switch. You can bog the car w/o even thinking. It's not for the feint in heart.
12-09-2008, 03:43 PM
#183
Originally Posted by NickAlero2000
Yea,
and not being able to intercool the s/c would hold me back a LOT(like 330 hp MAX before heat soak)...
you could intercool the supercharger, but it would have to be a custom setup, not the shit hEaton supercharger.....besides even with an intercooler you will outspin that puny 45 even the 62 before you make any real serious power....
12-09-2008, 05:49 PM
#184
turbo ftw. GT30 or if you want to go big dog GT4088r
12-09-2008, 11:20 PM
#185
Eventually on the G4088R.....
I want to enjoy the power in the low range while my goal is a lower range....
eventually I want to be in the 10's,
but first I'll break 12's and see where I am when the dust settles....
12-10-2008, 01:22 AM
#186
Haha. So the point between bogging it down and wheelspin is a very fine line? That's how the Volvo S40 T5 and S60R are. Just without the heavy pedal.
12-10-2008, 09:51 AM
#187
i think you should concentrate on 14s and 13s first.....
12-10-2008, 11:18 AM
#188
True. One second at a time. I figure H/O mani, 75mm LS1 tb, turbo, full 3'' turbo back catless exhaust, should sit me in the mid-low 13's to start...
12-10-2008, 01:19 PM
#189
Boost Guru
So are they wastegates settable...meaning can you set to allow up to a certain psi or do you buy them with a psi in mind...my bad that was a turbo newb question but im still curious....also a good wastegate would be pivotal for a twin-c setup huh...preferably an external
They come with a set spring in them for a certain boost pressure. Usually when you order it you can choose which spring you want and that will end up being your minimum boost pressure you'll be able to run on the engine. With a boost controller you can turn up the boost as much as you want, but you can never run below what the spring in the wastegate is set for.
You'd be best off getting a flange or something to match the HO manifold to the ports on the head. It's not just a bolt up and go type of deal. And why go catless? You can make the same amount of power with a high flow cat. Magnaflow #59959 is what you want...3" metallic high flow cat.
12-10-2008, 07:23 PM
#190
I don't have a cat............... actually I don't have much of an emissions system on the car save for the charcoal canister.
12-16-2008, 11:31 PM
#191
^lol nice^
found a REAL nice BOV cheap, a turbosmart one. Normally they run around 230 new. Got mine 50-new! The guy I got it from never used it, needed a higher HP capable one lol. So his loss is my gain
02-04-2009, 11:18 AM
#192
Got Spys intercooler, injectors from cobaltss.net coming, 38mm wastegate coming (Tial), as well as new vents for my vent-pod project. more updates to come with pics
