Old 05-16-2006, 02:24 PM   #1
DRA-GON
DRA-GON's Avatar
DRA-GON is an unknown quantity at this point
Is this the 80 series that will fit the 2.4?
http://www.7453217467431.com/products/prod...D=1147804617140
<img src=\'http://i11.photobucket.com/albums/a175/looper90/SIG.jpg\' border=\'0\' alt=\'user posted image\' />
DRA-GON is offline   Reply With Quote
Old 05-16-2006, 05:03 PM   #2
jlenko
jlenko is an unknown quantity at this point
Send a message via MSN to jlenko
Dunno about "fit" the Alero.... but that's a single 3" inlet with dual 2.5" outlets.... if you're running 3" pipe from the engine back, go for that... otherwise use the one with the appropriate size.
I'm using a Flowmaster 80 with single 2.5" in, and dual 2.5" out... mounted transverse under the spare tire well. But mine's a cavalier with the N-body IRS... fits just fine... kinda tight tho.
jlenko is offline   Reply With Quote
Old 06-12-2006, 05:11 PM   #3
Paladin
DRA-GON, I think that it is this one :
http://flowmastermufflers.com/products/ind...roducts_id=3295
Old 06-12-2006, 05:20 PM   #4
strtrydr
strtrydr's Avatar
^ You are thinking correctly...same one I have.
If you are replacing the tubing from the cat to the muffler do not go bigger than 2.5" because you will lose exhaust flow (scavange)!!
EDIT: I know i am in the wrong catergory as my car has the 3.4 but the exhaust should still be the same.
Old 06-12-2006, 09:11 PM   #5
Paladin
The Flowmaster Model: 42583 is the one that is 2.5" ID / Dual 2.5" OD .
Props strtrydr - I am a ex zoomie. Electronic Warfare systems spec
Old 06-12-2006, 09:26 PM   #6
strtrydr
strtrydr's Avatar
^Thanks, I'm a F-16 CrewChief...and props to you
