06-08-2006, 02:06 AM
Well I see that there have been some who have had great luck with their aleros and others like me who havent. I recently purchased a 99 Alero (GL?) 2.4/automatic with 130,000 miles. All was well but then I started having really weird problems after I began with some intake/exhaust mods. I did a different cat back with a flowthrough muffler and a ran a short ram that is connected to the stock hose ( just removed airbox). After a couple of weeks I noticed a lope that got more and more pronounced. No vacuum leaks, and no other issues that were discovered by me or the GM mechanic that would indicate the cause of the lope. He later told me I had a bad coil, needed different plugs because Autolite Platinums were no good, and I needed a new bank 1 O2 sensor. He wanted $400 to do it. I did it myself for under $100. Problems still there and the OBD code 171 (too lean) comes up intermitently. Car misses slightly when rpms are below 1500 and engine is cold. Today I go for a short jaunt and on the way back home car starts missing really bad. I stopped at autozone and pulled the ignition control module and it tests bad. Bought a new ICM( didnt notice they gave me the wrong damn one) and installed. Car cranks but wont start, 2 hours of using a multitester shooting wires and checking continuity I notice that the old module pinout is different from the new one and get the correct one. I also notice that on the plug wire/coil pack housing that #3 and #4 have arced and burnt out some of the plastic at the base of the electrode, so I replaced that as well. I ohmed out the new coils I installed last week, got new wires and reassembled everything. Everything from the ICM to and including plugs is brand new or a week old, but car runs rougher than it did when I first stopped in, and its spewing molten stuff out my new exhaust. Well it turns out my cat was completly plugged so I punched a hole in it because it was already toast to see if it helped until I take it back to my friends exhaust shop tomorrow and still ran very rough, now loud as hell obviously because of the exhaust leak and would not idle. When it died it did so very violently and shook the car very badly. I have another appointment for this friday for it to go back to the shop, but quite honestly I am at a loss for what exactly is wrong at this point. All I know is that after roughly 6 hours (with the wife there also) and $400 later I keep fixing one thing only to find another and dont know why. Any ideas or help would be great. I have had people say timing and either a bad cam sensor, crank sensor, or maybe even the PCM is bad. ARRRRGGGHHHHHHHHH! I like the car, but damn this is crazy. Please HELP
06-08-2006, 04:05 PM
Well after installing the new cat today at my friends exhaust shop I pulled the plugs. It was only firing on 1 cyl all the time and 1 other intermittently. Pulled the brand new ICU and it tested bad. Needless to say the gal at autozone that gave me the wrong ICU yesterday hid from me and my wife after the other one tested bad. Going to a diff store to get one that already was tested and tested good and update on how it goes
06-08-2006, 04:13 PM
Designated Drunk
that blows man...the arc-ing of 3&4 happened to me too actually
I'm baaaackk
06-08-2006, 08:32 PM
damn it just sounds like you're having all sorts of bad luck. I had the same problem with not running just right when I switched from a cai to a wai....sure enough, i switched it back and it hasn't ran this well in quite some time.
06-08-2006, 10:00 PM
I switched back to the stock airbox after the initial problems of reading to lean and still to no avail
06-12-2006, 09:17 PM
UPDATE:
Well according to Mr Goodwrench, Crank sensor is showing bad, but he also thinks its the PCM, but was checking the timing chain as well. When I spoke to him a little while ago he thought maybe the PCM was throwing a bad code for the crank sensor, but will let me know everything for sure tomorrow a.m. Was hoping things would be quicker and easier, kinda wanted the ho back today issed:
06-19-2006, 02:03 AM
It sounds like you've got people blindly replacing stuff, without knowing what they're doing.
Has anyone used a Tech 2 to check the duty cycle on the injectors? If you're throwing a lean code... you could actually have a fuel delivery problem... aka, clogged injector (what did the plugs look like when they came out?). You might have a dirty fuel filter.
It seems more than a little suspect to me, that you've been thru ICM and PCM and they're being found to be bad... that's pretty hard to believe.
06-21-2006, 02:18 AM
ICM was erroneously tested bad, it's now back in. The PCM however was bad, and had that replaced along with coilpack housing again (#3 ohmed bad). The fuel filter is new today. The GM Mechanic tested line pressure, but was not there when he did it to know from what points pressure was tested just that he said it was good. I suspect that it was only tested with line capped at the fuel rail inlet fitting and not a complete circuit. He did remark the fuel pump was going bad, but dont get how that could be if the pressure was good He also stated that he pulled injectors and 1 did have some gunk which he cleaned up. So at this point the alero is home and his brother will be doing the fuel pump at some point this week. It runs, but still has a slight lope, and until its warm will stumble a little til you hit about 1600 rpms. I personally think that if the pressure is good but delivery to cylinder is bad, either the rail has some obstruction or it's a injector problem still. Guess we'll see later this week issed:
08-15-2006, 08:22 AM
2 months later and another ho is revived. nice job pally!
