06-28-2009, 12:10 AM
Wide Open Throttle
Billet Engine Mount
06-28-2009, 12:44 AM
AutoCross Alero
beautiful! i'm waiting for a couple things on ebay to sell and i'll be owning one.
06-28-2009, 06:50 AM
4 left.
06-28-2009, 08:57 AM
wheres the one for the 4 bangers
06-28-2009, 11:06 AM
arent they the same?Maybe im wrong!
06-28-2009, 11:59 AM
Wide Open Throttle
This might fit the 2.4, but I don't know for sure.
06-28-2009, 12:29 PM
than check it out, that way you have a bigger market . Its really close, but even to try it in an 2.2 ecotec you need the base plate, which your not selling and if the top dont fit, think thats cake to make one that fits.
As im typing im getting ready to go take mine out and use the 3M Window Weld ghetto way to fix mine. And ordering the tranny ones for the 5speed. They are shot.
Here is a picture for your reference, so you can see the difference.
06-28-2009, 01:04 PM
Wide Open Throttle
Yeah I know nothing about 2.4s, sorry.
06-28-2009, 01:05 PM
is this stiffer then stock aswell or just mainly cosmetic upgrade?
06-28-2009, 01:15 PM
please read the item description at the link provided before posting questions. thank you.
06-28-2009, 01:17 PM
its stiffer!
06-28-2009, 08:05 PM
It should fit the 2.4L without a problem as the 2.4L & 3.4L share the same mount. Unfortunately it will not fit the ecotec.
06-29-2009, 01:28 AM
I would've already ordered one if it did fit the Ecotec though.. I would think it would be able to just make another bracket to fit the Ecotec and use the rest of the existing design.
06-29-2009, 10:22 AM
Id order one, but after reading the description of
"Due to the stiffer design, this mount will increase vibration, especially on cold startup and at certain RPM. We are still testing some methods to reduce the vibration"
I think I might wait for the redesign unless there won't be let us know ben
06-29-2009, 12:02 PM
3 left now ~:O
06-29-2009, 12:16 PM
woohoo! get 'em while they're hot.
06-29-2009, 12:55 PM
Wide Open Throttle
We don't plan to redesign the mount itself for the vibration.
06-29-2009, 01:00 PM
Wide Open Throttle
well here we go This is from Phil
"Update:
The issue with the slight increase in vibration has now been addressed and cured. Since the N-Body's subframe is not isolated from the rest of the body with rubber bushings, pieces of Viton Rubber were used between the bottom portion of the mount and the frame rail. I also put the Viton Rubber on the other two mating surfaces of the mount and the vibrations are now gone."
This viton will be included with the first 5 orders. I hope to have updated pictures soon.
06-29-2009, 03:55 PM
Only 2 left.....now
06-29-2009, 04:24 PM
Wide Open Throttle
1 left
