Old 10-13-2009, 06:07 PM   #1
Xtrm
Xtrm's Avatar
Xtrm is on a distinguished road
Send a message via MSN to Xtrm
Center Colsole
I would like to know how I go about taking out my center console. Everything from the dash to the gear shifter.
2003 Alero GLS 3.4L
Xtrm is offline   Reply With Quote
Old 10-13-2009, 08:44 PM   #2
Caboose73
unscrew the screws that are holding it in place
Old 10-13-2009, 09:19 PM   #3
-2 screw un front by your feet right under where the dash meets is.
-2 screw inside the center console, take the bottom rubber mat out.
-2 screws b/t the seat and the console, on the side and closer to the back. slide the seats back all the way and you can get them.
-Pry out the u shaped pin on the front of the shifter. pull shifter up and off.
-pry (well, pop) off the trim around the bottom of the shifter. unhook trac button wire and bulb for shift indicator. lift out
-pull out center consloe up and towards back seat.
you will need a 1/4 inch rachet, forget what size socket, but all the screws are the same size, a long extension to reach into the center console hole, and a regualr size flat blade screw driver.
that help?
Old 10-13-2009, 09:38 PM   #4
that help?
Rep Given, great how to!
Old 10-13-2009, 10:53 PM   #5
Ian 2000GL LA1
Ian 2000GL LA1's Avatar
Ian 2000GL LA1 is on a distinguished road
Send a message via AIM to Ian 2000GL LA1
just use an hammer and a flat head screwdriver. JK.
Ian 2000GL LA1 is offline   Reply With Quote
Old 10-13-2009, 10:57 PM   #6
Caboose73
what no rep for me?
