Old 02-01-2011, 10:59 PM   #1
lowolds1
lowolds1 is on a distinguished road
Exclamation burns oil at higher rpms
can anyone help me fix this?...it doesnt do it much unless i crack on it and i can see it smoke a little and it reeks. help please?
lowolds1 is offline   Reply With Quote
Old 02-01-2011, 11:49 PM   #2
Your rings are probably on the way out. That or the valve guides are warn
Old 02-02-2011, 08:24 AM   #3
colonel6632
colonel6632's Avatar
is it a 2002? mine used to do that... then the motor blew up. once it starts burning oil, there isn't normally much you can do
Old 02-02-2011, 09:21 AM   #4
Lucalare
I would say your rings are going bad.
1987 Honda Rebel 450
Old 02-02-2011, 12:05 PM   #5
Run a compression test and see what you get
Old 02-02-2011, 12:09 PM   #6
lowolds1
its a 2003 and ill do a compression test here soon and let yall know
Old 02-04-2011, 01:01 AM   #7
My original engine burned a little oil, but never had any effect on the way it ran or anything. Maybe a quart per oil change.
Old 02-04-2011, 01:12 PM   #8
BlueLego
BlueLego's Avatar
BlueLego is on a distinguished road
i read up on a article of the valve cover being deffective. the heat steaks in the older eco's would burn up the oil and then send it back through the intake as fumes and burn it up. or seomthing like that. i just posted a thread seeing if an 04 valve cover would work because it said to replace it with a newer model VC
BlueLego is offline   Reply With Quote
Old 02-04-2011, 04:52 PM   #9
lowolds1
hmm thanks let me know if thats true and ill have to do the change
