05-02-2011, 04:45 PM
Aftermarket Radio Harness
So as before looking to get a dvd/cd player and when looking at the harness to use the only thing I can find is from scosche model # GM09SR. Is there anything more simple/cheaper? Really don't mind not having the "chime saver" module if not needed. Would like a simple harness like I used to use on other cars granted I never had a RDS radio before.
05-02-2011, 06:17 PM
year and do you have the /\/\oonsoon ( sorry a key is not working on the keyboard I think you can figure which one )?
05-02-2011, 06:28 PM
lol well it's a 2003 and yes has monsoon.
05-02-2011, 06:52 PM
05-02-2011, 06:53 PM
Any regular harnesses out there?
05-02-2011, 06:55 PM
that is regular harness
05-02-2011, 07:09 PM
sorry my computer delayed and didn't know you had replied. Thank you by the way!
05-02-2011, 08:12 PM
np
05-04-2011, 01:46 PM
That's still a little confusing and doesn't explain why some wires are removed and not used and why the other wires are used/hooked up the way they are? Little confusing I guess
05-04-2011, 08:45 PM
so pretty much I can leave it the way it is and it will work fine? and how is there no wire to hook the red 12V to?
"When connecting all the wires from the aftermarket radio to the harness, use your amp remote wire from the radio, not the power antenna wire, or you will only get sound when listening to FM/AM.".....
this part is confusing
05-04-2011, 08:49 PM
that is confusing ive never heard that before
05-04-2011, 09:06 PM
i have a harness that is like that although it is blue, hasn't been used but i cant find the bag for it. Pm me if you want it and i will just send it to you.
looks somethin like this : http://www.amazon.com/Stereo-Harness...57546&sr =1-1
100,000 Mi 3/29/2011
05-04-2011, 09:15 PM
HMMMM. Where's all the sound guys when you need em? I'd like to try it this way, but want to be more clear on the directions and as to why each step is needed? (Illumination feature? Amp power wire? 12V red wire?)
05-04-2011, 10:32 PM
I believe the Illum. wire is to dim the stock headunit when you scroll the dimmer switch. Amp power wire? may be the 12v red wire (thought it was blue?) this wire is used to turn on the amplifier when your head unit is on.
05-05-2011, 02:00 PM
Bump?
05-05-2011, 07:28 PM
Are you not finding my information useful?
05-05-2011, 07:59 PM
Well yes usually the amp power wire is blue and usually hooks to a blue wire on aftermarket radios but the way it is described is almost as if I am to hook up the amp wire to the improvised 12v red wire that is connected to the sunroof fuse? Also is there no other way to power the new cd player?
05-05-2011, 09:00 PM
You need to use a fuse tap to a switched 12v to get power because you loose RAP (retained acessory power) and switched power, if you dont use the module. The Blue/white wire you connects to your decks remote or amp turn on wire so it turns on your monsoon amp like a regular amp. And Im assuming the blue/white wire will turn on you antenna booster too, because thats what the wire is normally used for. I have never done this, but realized I could have done this after I spent $90 on an expensive chime module.
05-05-2011, 09:07 PM
Never used a fuse tap, how n where can I get one? I kno I'm gona get flak for this
