01-20-2008, 04:50 PM
Stock Alarm
On my alarm that came stock with the car, for the Keyless confirmation it has the parking light flash, but just because i am lame like this, is it possible to wire a horn to that aswell?
or am i better off getting a new alarm system
01-20-2008, 09:08 PM
uhhh... when i push lock twice, my horn beeps once to confirm its locked. it has something to do with the setup. read your manual, it should explain what it can and cannot do.
2000 Chevrolet Malibu LS
01-20-2008, 10:48 PM
Yeah, you can make the horn honk in the vehicle personalization settings. Check your owners manual for how to do it.
01-20-2008, 11:29 PM
How do ya change it, the owners manual I got with the car was in french
2003 Alero
2.2 5speed
Grey
1996 GMC Yukon 4x4
01-20-2008, 11:46 PM
See if you can find an English one on eBay
01-20-2008, 11:48 PM
2003 Oldsmobile Alero
Vehicle Personalization
Modes of Operation
Automatic Door Locks (Manual Trans)
The following are the modes of operation for the automatic door locks feature:
* Mode 1: All of the doors lock when the vehicle speed exceeds 8 km/h (5 mph). All of the doors will unlock when the transaxle is shifted into REVERSE (R) and the key is turned to OFF.
* Mode 2: if equipped with RKE All of the doors lock when the vehicle speed exceeds 8 km/h (5 mph). Only the driver door unlocks when the transaxle is shifted into REVERSE (R) the key is turned to OFF.
* Mode 3: All of the doors lock when the vehicle speed exceeds 8 km/h (5 mph). No automatic door unlock.
* Mode 4: No automatic door lock or unlock.
Automatic Door Locks (Automatic Trans)
* Mode 1: All of the doors lock when the vehicle is shifted out of PARK. All of the doors unlock when the vehicle is shifted into PARK and the key is turned to OFF.
* Mode 2: All of the doors lock when the vehicle is shifted out of PARK. Only the driver door unlocks when the vehicle is shifted into PARK and the key is turned to OFF.
* Mode 3: All of the doors lock when the vehicle is shifted out of PARK. No automatic door unlock.
* Mode 4: The automatic door lock feature is disabled.
Programming Features
Enter Programming
To enter the programming mode, perform the following actions:
1. On a vehicle with a manual trans, place the trans in REVERSE. Apply the park brake.
2. Close all of the doors.
3. Turn the ignition to the RUN position.
Continue with the following steps in order to personalize the automatic door locks:
1. Press hold the LOCK button on the power door lock switch for 10 seconds. The vehicle will chime with the number of chimes corresponding to the current mode. Refer to Automatic Door Locks modes.
2. Press and hold the LOCK button on the power door lock switch for 10 seconds again in order to advance to the next mode. The vehicle will chime with the number of chimes corresponding to the mode.
3. Continue to press and hold the LOCK button on the transmitter until the desired mode is reached.
Remote Activation Verification
Continue with the following steps in order to personalize the horn for the remote activation verification feature:
1. Press and hold the power door lock switch in the UNLOCK position for 10 seconds. The horn will chirp when the horn setting for the remote activation verification has changed between disable and enable.
2. Press and hold the power door lock switch in the UNLOCK position for 10 seconds again to change the horn setting back to the original setting. The horn will chirp when the horn setting for the remote activation verification has changed.
Exit Programming
Any of the following list of events will cause the programming sequence to be terminated:
* The ignition is moved from the RUN position.
* The vehicle is shifted out of REVERSE for vehicles with a manual trans.
* The park brake is released for vehicles with a manual trans.
Chime Level Adjustment
In order to adjust the chime level, perform the following steps:
1. Turn the ignition ON.
2. Turn the radio OFF.
3. Press and hold the radio push-button 6 until either LOUD or NORMAL appears on the radio display. The chime sounds 3 times for each volume change.
4. To toggle the setting, press and hold the radio push-button 6 again.
01-21-2008, 07:41 AM
sweet! thanks!
2003 Alero
2.2 5speed
Grey
1996 GMC Yukon 4x4
01-21-2008, 06:25 PM
Great thanks, im gonna try that now
01-21-2008, 10:17 PM
Work great! thanks, now what else have you guys done if anything in the way of personal preference/personalization???
