Old 05-14-2012, 02:01 PM   #1
irondiezl3
irondiezl3's Avatar
how is this mono block when it has 2 channels
http://www.jbl.com/estore/jbl/us/pro...sp?pid=GTO3501
ok so how is this mono with 2 channels.
and how does it put out 360rmsx1 when it doesnt say bridgeable im confused help please.
Old 05-15-2012, 01:19 AM   #2
It would be decent. You need a sub box? Im still trying to get rid of my old thats molded for the alero trunk.
Old 05-15-2012, 08:33 PM   #3
Hectic
Hectic is on a distinguished road
It's for ease of wiring.
My old Kenwood was the same way.
Allows for more choices of wiring options + using larger (0/1 gauge) Gauge wire without having to jam both into the same output.
1999 GX LD9 Sedan -- RIP 'ho
Hello 2012 Sonic LT
Hectic is offline   Reply With Quote
Old 05-23-2012, 01:38 AM   #4
irondiezl3
irondiezl3's Avatar
got new stereo in for some reason anytime i skip tracks or pause the headunit the subwoofer pops lightly. none of the mids pop just subwoofer i checked all connectioons are clean and tight wtf is causing this?
Old 05-23-2012, 01:44 AM   #5
Bad ground or pinched rca???
Most likely a bad head unit or amp though...
Old 05-23-2012, 12:59 PM   #6
irondiezl3
irondiezl3's Avatar
ok so when i take out the rcas from the amp no more poping at all amp still has power ground speaker and remote connected just take out the rcas and it goes away put them back in and its there. my friend thinks its the headunit but its a really good headunit and my 4 mid speakers dont do it at all and they have an amp to them
Old 05-23-2012, 01:06 PM   #7
Doesnt mean a small part in the headunit wasnt defective
Old 05-23-2012, 02:46 PM   #8
irondiezl3
irondiezl3's Avatar
hmmmm i cant believe how stumped i am if the poping when i skip wont hurt anything i can deal with it. any idea whats more likely the new amp or headunit causing it?
Old 05-23-2012, 05:53 PM   #9
Head unit IMO... But I'm no audio guy by any means
Old 05-24-2012, 09:29 AM   #10
irondiezl3
irondiezl3's Avatar
i just lisened to it again and i can see my sub actually moving to the idle in my motor man i hope that means its just a bad ground.
Old 06-19-2012, 09:13 PM   #11
Its the head unit more than likely.
Pull the unit out. Take the ground right off the harness of the radio (not the adapter plug) and put it to bolt in the center console.
If that doesnt seem to fix it take another set of RCAs and just run them above the carpet to test if its the RCAs picking up noise. I highly doubt the rcas since you are getting alternator whine.
Lastly your alternator might be on its way out.
Old 06-19-2012, 09:18 PM   #12
I hope he has figured this out by now!
Old 06-26-2012, 11:02 PM   #13
irondiezl3
irondiezl3's Avatar
wow it was the amp got new amp all gone phewwww
Old 07-14-2012, 04:15 PM   #14
DRM Racing
DRM Racing's Avatar
DRM Racing has a reputation beyond reputeDRM Racing has a reputation beyond reputeDRM Racing has a reputation beyond reputeDRM Racing has a reputation beyond reputeDRM Racing has a reputation beyond reputeDRM Racing has a reputation beyond reputeDRM Racing has a reputation beyond reputeDRM Racing has a reputation beyond reputeDRM Racing has a reputation beyond reputeDRM Racing has a reputation beyond reputeDRM Racing has a reputation beyond repute
road noise or alternator whine is caused by two things. A bad ground to the chassis or inside the amp or RCA feedback which can be caused by the rca jacks being to close to the power wire. The popping is negitive feedback and as said up above can be a bad amp or your RCA jacks.
DRM Racing is offline   Reply With Quote
