if its the rear door, this is what you do
once the trim panle is removed, you will see the door latch, and the handle and the rod
on the latch is a clip where the rod attaches to, you can unclip it, and try to move the rod up,
if that does not work, the handle has a small spring in it no fix there and a new handle is in order
if ya cant figure it out let me know or stop by the shop i will fix it for ya
