Old 12-08-2008, 07:09 PM   #1
coolgrinder33
coolgrinder33's Avatar
coolgrinder33 is on a distinguished road
wtf does the alero "security" system do
you can read about it in the manual...and it shows it on the radio and dash...but i see no effects lol
coolgrinder33 is offline   Reply With Quote
Old 12-08-2008, 07:13 PM   #2
Midgear
on vacation
it will cut the fuel pump should it detect any kind of tampering or suspicious behaviour.. such as a crappy key, old cylinder, or sometimes even tripping for no apparent reason.
WILL NEVER FORGET
Old 12-08-2008, 08:34 PM   #3
^^ You forgot the theft of the car
GM cars back in the day were VERY easy to steal. All you had to do was break the ing lock, which was also easy, and turn the cyl without the key and the start would start.
Well Gm beat that rep by putting in a crappy passlock system that is so good, sometimes it prevents the owner from driving away in their own car
Old 12-08-2008, 09:24 PM   #4
Alero_1986
Alero_1986's Avatar
Alero_1986 is on a distinguished road
emphasis on this point!
Alero_1986 is offline   Reply With Quote
Old 12-09-2008, 10:24 PM   #5
CactusWill
And often times the thief didn't really have to break anything. Just pop a flathead screwdriver into the keyhole, a quick twist and they were on their merry way.
Old 12-09-2008, 11:25 PM   #6
I could start the Delta without a key, sometimes
Old 12-09-2008, 11:44 PM   #7
Same with our 87 cutlass supreme we used to have a long time ago.....
Old 12-09-2008, 11:46 PM   #8
Vinalero
Vinalero's Avatar
Hahaha my 86 Camaro didnt need a key to start it either.
